another operating temp question
Old Oct 10, 2011 | 09:06 AM
boltnut's Avatar
boltnut
Default another operating temp question
how long does it take your C3 to get to full operating temp on a cool day (lets say 65 ambient)
assume no heat crossover is being used.
180 thermostat
OE rad
i notice mine hits full temp on the gauge in less than 15 minutes easy.....BUT it seems another 10-15 minutes of driving before it really drives like its fully warmed up....
Old Oct 10, 2011 | 10:28 AM
7T1vette's Avatar
7T1vette
About 10 minutes. Do you have a thermostat installed? Has it failed in the 'open' position? If you remove it, and the 'flapper' is still open, the stat is bad. If you have no T-stat, it will take 15-20 minutes to fully warm up.
Old Oct 10, 2011 | 10:45 AM
MelWff's Avatar
MelWff
without the heat crossover it will take longer than normal since your intake manifold stays cooler for a longer period of time.
Old Oct 10, 2011 | 11:14 AM
boltnut's Avatar
boltnut
180 high flow tstat. the gauge reads up to temp in about 10 minutes.
what im saying is the car does not RESPOND like its fully warmed up for another 10-15 minutes of driving...
Old Oct 10, 2011 | 12:31 PM
MelWff's Avatar
MelWff
thats because you have no heat to the intake manifold
Old Oct 10, 2011 | 12:54 PM
boltnut's Avatar
boltnut
Im cool with that ! wanted to be sure....
Old Oct 10, 2011 | 01:52 PM
PeteZO6's Avatar
PeteZO6
Aluminum heads and intake with no heat crossover on mine. Because there is no warming under the carb, fuel doesn't vaporize as quickly and sometimes causes a stumble on acceleration until thoroughly warmed.
Old Oct 10, 2011 | 02:07 PM
boltnut's Avatar
boltnut
yes ....was trying to tune that stumble out
was concerned i may have a vac leak that sealed after it warmed up too..
all is good now...
Old Oct 10, 2011 | 02:42 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
Are you using a mechanical choke? Mine takes about 5-10 minutes for the coolant to come up to temperature, but sometimes another few minutes before the choke fully disengages and the car starts performing like it is fully warmed up.
Old Oct 10, 2011 | 02:57 PM
boltnut's Avatar
boltnut
electric choke and its coming off too soon now that its getting colder out....i cant even drive the car until it hits like 160 or so...
Old Oct 10, 2011 | 03:01 PM
MelWff's Avatar
MelWff
Is you vacuum advance hooked to ported or manifold source. If ported switch to manifold and initial cold driveability issue will improve.
Old Oct 10, 2011 | 03:09 PM
boltnut's Avatar
boltnut
thanks....on manifold source now. against the advice of holley tech :o)
Old Oct 10, 2011 | 08:01 PM
PeteZO6's Avatar
PeteZO6
An electric choke on a Holley is pretty much infinitely adjustable so you should be able to get it to not come completely off until the engine is warmed. The black bakelite houseing is rotated towards RICH to delay the choke coming off, and LEAN to speed it coming off. There is also a fast idle adjustment screw to get the idle the speed you want while the choke is on.
Pete
To another operating temp question
