three prong flasher
Old Oct 11, 2011 | 10:46 AM
allboutvets's Avatar
allboutvets
7th Gear
Default three prong flasher
my blinkers went out on my 77 vette, i found the two prong flasher on passenger side and changed it still no luck. I was told there was a second flasher so i started looking and found a second flasher under dash so hot i couldn't touch it.Nobody seems to know what it is. It is silver with a black ground strap coming out of it and a wierd pin config. I have spent hours on this and ran into a dead end, please help. P.S. I would like to put an electronic flasher in.
Old Oct 11, 2011 | 10:58 AM
7T1vette's Avatar
7T1vette
Well, that "hot" flasher may or may not be for your "blinkers" (turn signals or emergency flashers??), but it is most certainly a failed flasher unit. It must have failed in a 'short' condition for it to be hot. You should remove it, no matter what else you do. It will certainly cause a constant drain on the battery (maybe not with the key "OFF"), and a "hot" component is never a good thing.
It should have a part number on it; find a replacement and plug it in. Hopefully, that will fix your problem...but it will certainly repair a 'fault' that should be addressed anyway.
Old Oct 11, 2011 | 11:09 AM
allboutvets
7th Gear
Default three prong flasher?
Took it off and took it to everyone I could think of nobody knows what it is nor can they cross reference the number Phillips 294.
Old Oct 11, 2011 | 11:16 AM
MelWff's Avatar
MelWff
Is this the part?
http://www.ecklerscorvette.com/corve...1974-1989.html
Old Oct 11, 2011 | 11:26 AM
allboutvets
7th Gear
Default three pin
horn works and that is not right config. config has two offset horizontal pins with black wire in line with them and a vertical pin under other pins.
Old Oct 11, 2011 | 11:37 AM
Peterbuilt's Avatar
Peterbuilt
Is the second flasher you found in the fuse box?
http://www.europeancorvette.com/phot...77/Page007.jpg
Old Oct 11, 2011 | 11:51 AM
MelWff's Avatar
MelWff
I think you are describing a Philips relay or similar devise that is not original equipment. Do you have any modifications to your car as far as lighting, LEDS, fog lights, neon lights, etc.? When you says pins do you mean blades?
Old Oct 11, 2011 | 12:02 PM
allboutvets
7th Gear
Default pins- meant blades
There are no such mods. As far as i can tell the only thing affected is blinkers. Auto zone has a three blade flasher relay listed for 77 corvette but no picture and special order.
Old Oct 11, 2011 | 12:05 PM
allboutvets
7th Gear
No, it was on a wiring harness between dash and steering coluum
Old Oct 11, 2011 | 12:56 PM
Peterbuilt's Avatar
Peterbuilt
Default A long shot!
If you can tell what color wires it's spliced into you might figure what circuit it's taped into.
Old Oct 11, 2011 | 01:05 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
That is the delay timer for the interior lights. They are no longer available.
If you want to eliminate it connect the white wires together and the lights will work without a delay.
Old Oct 11, 2011 | 03:57 PM
allboutvets
7th Gear
I'm guessing there is no substitute for it except eliminating it?
To three prong flasher
