Taking off Emblems
Old Oct 11, 2011 | 02:35 PM
optiman's Avatar
optiman
Default Taking off Emblems
I want to restore all my emblems off my 79. Side ones look like double sided tape. Any trick what to use, without wrecking paint?
Old Oct 11, 2011 | 02:44 PM
MelWff's Avatar
MelWff
blow dryer?
Old Oct 11, 2011 | 02:58 PM
dembo's Avatar
dembo
And a thin nylon string when thing are warmed up
Nick
Old Oct 11, 2011 | 04:36 PM
optiman's Avatar
optiman
someone once told me to try WD40. bad ideal? hurt finish of paint?
Old Oct 11, 2011 | 10:56 PM
vettehardt's Avatar
vettehardt
I don't think WD40 would do much to help get the emblem off. It will help get the adhesive off once the emblem is off, but I would use Goof off or Goo Gone for that.
I would use a heat gun or blow dryer to get the adhesive warm and then use a plastic puty knife to gently pry the old emblem off. I'm not sure ,but does the 79 emblems have prongs with speed nuts on the back like the stingray emblems do? If so, make sure to take the nuts off before trying to remove the emblem.
Old Oct 12, 2011 | 04:28 AM
dgood's Avatar
dgood
the side emblems do have prongs on them but when I took mine off they did not have speed nuts, just double sided tape. I have heard people using dental floss to get behind them. I was not worried about damaging the paint because I painting the car.
Old Oct 12, 2011 | 08:14 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
Hey have a look at my article on this I did the ones on my 80 . http://www.capitalcorvetteclub.ca/
Look under Ron's tidbits. Dec 09
Old Oct 12, 2011 | 09:00 AM
optiman's Avatar
optiman
thanks everyone, can't wait to get started. I will post before and after pictures when completed.
Old Oct 12, 2011 | 09:19 AM
Scott1980's Avatar
Scott1980
I have used fishing line in the past after heating up the badge. Also waited for a warm day.
Old Oct 12, 2011 | 11:09 AM
esierra's Avatar
esierra
Nick
Dental floss works well
Old Oct 12, 2011 | 11:48 AM
Vette5.5's Avatar
Vette5.5
Pretty sure after mid 70's everything went to double faced tape. An infra-red bathroom heat lamp(with sunglasses) should help pull these off. Maybe a bit of light thinner clean up too. Find 3M Scotch-Mount Super Strength molding tape and some bench ex-acto knife cutting, puts things back quite well.
Old Oct 12, 2011 | 12:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Why not order the assembly instruction manual (AIM) and read how they were installed at St. Louis. The process involved heating the emblem and the emblem tape. If you remove them, you probably will not be able to use the heat method to reattach them.
Have you considered cleaning them up with them on the car?
Old Oct 12, 2011 | 12:56 PM
jdolomount's Avatar
jdolomount
I took mine off a while back and used Dental floss. Clean up any residual glue and foam with a bit of Varsol or goo gone.... No problems.
If you use a heat gun and apply to much, you may risk bubbling the paint.
Old Oct 12, 2011 | 01:10 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
Here's how I did mine took 2 minutes slide the knife till you hit the align pin.Ron
Old Oct 12, 2011 | 01:15 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
Here's the new one installed
Old Oct 12, 2011 | 01:25 PM
7T1vette's Avatar
7T1vette
Unwaxed dental floss is the thing to use. It will fit into very narrow gaps; it is strong enough not to break under some stress; it cuts through tape fairly well. Tie off the ends to a couple of wooden dowels, then use it like a 'saw' to cut through the tape. You will quickly discover how taut you need to hold the floss and how much stress you can put on it as you are 'sawing' through the tape. Fairly painless process and it will not damage underlying paint. Use Goof Off or other solvent (like Prep-Sol) that won't damage your paint to remove remaining tape residue.
To Taking off Emblems
