QuadraJUNK
Old Oct 17, 2011 | 09:50 AM
Ganey's Avatar
Ganey
Default CARBS Tests HP/TQ
A square bore carb should be sized properly to the engine, so many sizes are offered.
The GM solution: Q-J. The spreadbore has small primarys which allow velocity, response & fuel economy while the huge sec. provide capacity. The cfm rating of what it is capable of is not relevant on smaller engines- it works well because of the small primarys.
The Q-J is basically GM’s one size fits all V8 carb & notice how many different 350s from GM came out after the Q-J ...
CARBS Tests TQ/HP
http://www.corvettefaq.com/c3/carbcomparo.htm
While we could do w/o the Quadrajunk comments, some of the Q-J fans comments are as bad...
The Holley was designed to be a perf. carb.
Old Oct 17, 2011 | 10:34 AM
jb78L-82's Avatar
jb78L-82
Originally Posted by johnt365
I would like to see an A/F ratio graph for a Holley for comparison if anybody has one they can post from a dyno run. Let us know the model too.
Check out my dyno sheet under my recent post about my L-82 first time on the dyno with the Holley 4175 carb which has the A/F ratio graph half way down the first page of the post. The holley 4175 was pretty much dead on below 3,500 RPM and then leaned out slightly up to 5,500 RPM, but just slightly.
Old Oct 17, 2011 | 12:02 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by Vette5.5
Q-Jets have been called many names over the years, and beeing out of production for years now, tuning parts are getting harder to find. While Holley and Carter parts are easier to find, bettin' you'll be looking at distant fading tail lights of well set up Q-Jet car on the street.
So that's the reason you see so many at the drag strip
Old Oct 17, 2011 | 12:05 PM
BKbroiler's Avatar
BKbroiler
I ran 12.49 at 107 two times Saturday with my Qjet. (At the drag strip.)
Old Oct 17, 2011 | 08:40 PM
68FireBird's Avatar
68FireBird
Some Quadrajet links for part I found while tuning mine should you decide to go that route. I went with Cliffs.
http://www.carburetion.com/quadrajet.asp
http://www.cliffshighperformance.com/parts.html
http://quadrajetparts.com/
Cliff is the man. I tried running a edelbrock performer AFB clone (750 cfm) on my Pontiac 400 and it would not run right no matter what I did. Switched rods jets etc.....following the book. I had Cliff build me a Q-Jet and it went from a slug that would hardly burn the tires to a 13.8 qtr mile. I'm guessing 30 + horse power gain. This was 7 or 8 years ago and the carb is running great, haven't touched it other than idle mixture when I set the timing.
Mike
Old Oct 17, 2011 | 09:30 PM
Tim H's Avatar
Tim H
I don't think I have ever saw a quad on a car at the dragstrip.
Old Oct 17, 2011 | 10:28 PM
68FireBird's Avatar
68FireBird
Mine has only been down twice, so I'm betting it's a rare site.
Old Oct 18, 2011 | 09:40 PM
Oldguard 7's Avatar
Oldguard 7
My guess is that theyre so many parts to it that it would take much more time to get it set up properly between races. But you see not everyone drag races. Properly tuned it performs just as well as a Holley. People should take the time to learn to properly set them up and tune them and I bet the name calling will be to a minimum.
Old Oct 18, 2011 | 10:04 PM
noonie's Avatar
noonie
The implications here are all over the place.
GM did calibrate a few Qjets for high performance in the early years, mostly on Pontiacs and Buicks, while the Chevy line used mostly Holley.
Later Qjets were calibrated primarily for emissions while AFTERMARKET Holleys were designed for performance.
That is why most Holleys and variants are also labelled "For off road use Only"
I don't know why this is so hard to understand. Apples and Oranges.
It's no different than turning an oem L48 160hp into a 350hp sbc.
That's not to say that a Qjet cannot be rather heavily modified (not just tuned) to perform comparable to an AFTERMARKET performance carb.
Cliff Ruggles has been backlogged for many years for these modifications at any given time of anywhere from 4 months to well over a year.
Not the kind of work your average carb rebuilder or carb tuner does.
Old Oct 19, 2011 | 07:24 AM
Tim H's Avatar
Tim H
Originally Posted by Oldguard 7
Properly tuned it performs just as well as a Holley. People should take the time to learn to properly set them up and tune them.
Please take time to compare procedures to "properly tune" a quad verses a Holley.
Because I have done it and that why I have my opinion of whats better and easier.
Old Oct 21, 2011 | 11:53 PM
Oldguard 7's Avatar
Oldguard 7
That is good for you. You have your opinion and I have mine.
Old Oct 22, 2011 | 10:09 AM
Tim H's Avatar
Tim H
Again, a 4 year college education shouldn't be required to tune a carburator.
If you have to buy a $20 book and search for parts for weeks it kind of takes out the "fun" factor.
Run a quad until it breaks and throw it in the corner and get a Holley = drive and be happy!
Old Oct 22, 2011 | 11:39 AM
  #33
damoroso's Avatar
damoroso
Doesn't take a 4 year degree, and once you learn them it's not a big deal. The biggest difference is that the Q-jet has three circuits vs. the Holley and others that have two and because of that have more variables for tuning. You can find all the parts you need at a couple of websites, Cliff's is one of them. It's like everything else, just a choice. As for racing, there are some guys running Quads, but the majority are probably running something else that's more designed for racing. As most of us don't drive the same of the street as we do at the track, so IMHO that's comparison doesn't make sense. Think about it, at the track how much time do you spend in the cruise range of a carb? It's basically idle and WOT...
Old Oct 22, 2011 | 08:18 PM
  #34
Jeff_Keryk's Avatar
Jeff_Keryk
I love my QuadraJunks... Got one on my 68 L36 Roadster and my immaculate 65 442.
Old Oct 22, 2011 | 08:37 PM
  #35
johnt365's Avatar
johnt365
Originally Posted by Blitz72
It works ok but takes forever for the choke to come down.
Blitz72,
Do you feel your original question was answered? Did you know carburetors could create such a maelstrom of debate?
I noticed your original issue is with the choke. What type of choke does your qjet have on it now? Perhaps there is an easy fix.
John
Old Oct 22, 2011 | 08:54 PM
  #36
Tim H's Avatar
Tim H
Oldsmobiles are aloud to have quadrajets.
Old Oct 23, 2011 | 07:58 PM
  #37
MotorHead's Avatar
MotorHead
If anyone thinks a Holley is easy to tune then explain to me what high speed air bleeds, idle air bleeds, emulsion jets, power valve channel restictors, idle feed restictor, air hole size, transfer slot restrictors, do. And what effect they have on the tuning of the carb if you go up or down on the size and if you change one thing should you be changing another ?
This is of course off the top of your head without looking each one up on google.
Anyone who spent 2 years in grade 9 can change a jet size you need grade 10 to start playing around with idle mixture screws
I have a 825 Drag Race Demon on my 427ci and it runs perfect and I get 24 mpg on the highway
Old Oct 23, 2011 | 08:41 PM
  #38
bpassmore's Avatar
bpassmore
Old Oct 23, 2011 | 10:16 PM
  #39
birdsmith's Avatar
birdsmith
There seems to be a QJet crowd and a Holley crowd on this forum. QJets are popular with C3 owners I think because of the limited hood clearance issue (That's why I've kept mine) but for ease of tuning, no-waiting seconday opening, bowl capacity, and several other reasons Holleys have it all over the Rochester. It is true that you can tune a QJet to work very well on a well-tuned, high-performance small block but it's still essentially a vacuum secondary (read:delayed response) carb that is fiddly to work on even on the best of days. If I want to change a power valve or jets on my Holley all I have to do is pull off the float bowl and do it. Try that with a Quad and I have the whole carb scattered all over the workbench for a couple hours and it's a miracle if it goes back together right the first time with no leaks and the choke still working right. That's why Holleys are always gonna be the favorite of guys that like to tinker with their cars and why NASCAR has continued using them into the 21st century...they just work.Problem is, they don't fit under a C3 hood very well...
