Headlight "UP" adjustment?
I spent a good part of yesterday adjusting them per the AIM (UPC12 A2 & A3) and service manual and they seem to be adjusted fine. The links goes a bit over center and lock out. The warning switch is being pressed and the L bracket stop is touching the headlight frame. The lights are nice and solid in their up position. And they line up nice when closed.
I've read all the posts I could find and still don't see a way to control the UP position once the link is fully opened and locked out.
Driver side up higher than passenger side:
Passenger side:
Driver side link:
Passenger side link:
Any chance that it's the bezel and not the mechanism adjustment?
Is it mounted correctly?
Have the bezels been off?
Can you take both off and put them next to each other on a flat surface to see if one of them is 'warped'?
How do the doors look in the closed position? Does the front corner of the headlight carrier need to be shimmed down a little?
That's all I can think of now.
Good Luck!
Regards,
Alan
Mount:
Now they line up pretty well.
Because I got them working so well now, I took a video. I was actually curious to see the linkage in action. Enjoy.
Outside:
Now you have to get the open and close together.
Could be the actuator:
http://www.corvette-101.com/vacuum.htm#actuator
Or the relay:
http://www.corvette-101.com/vacuum.htm#relay
You'll soon have them 100%
Azza
