thoughts on differential drain plug
Old Oct 20, 2011 | 09:42 AM
7t9l82's Avatar
7t9l82
Default thoughts on differential drain plug
i know some have done it and i think it may be a good way to get more garbage out . any suggestions on how or why not?
Old Oct 20, 2011 | 10:17 AM
gcusmano74's Avatar
gcusmano74
Yes. I had the bottom of the diff drilled and tapped 1/4'' NPT for a drain plug many years ago, with no problems. My car is a street driven small block. I needed to put a bit larger hole in the strut bracket to access the plug. I just had the shop make the hole dead center while the diff was apart, but I've seen a paper pattern with drill bits and a tap for sale recently (at Corvette Central, look at 582267) that offsets it a bit.
Old Oct 20, 2011 | 10:33 AM
joewill's Avatar
joewill
you guys are just making more work for yourself. Those rear ends will go for decades and 100,000 miles without an oil change.
Old Oct 20, 2011 | 10:41 AM
6inarow's Avatar
6inarow
Ok, noob here.
I have read several threads where its recommended to change gear lube and add the posi additive.
So, what gives??? lube change or no change?
Old Oct 20, 2011 | 10:50 AM
Ganey's Avatar
Ganey
... Those rear ends will go for decades and 100,000 miles without an oil change.
True.
6inarow
That's normally suggested when there is noise from the posi.
So which 6? DOHC Jag?
Old Oct 20, 2011 | 10:52 AM
6inarow's Avatar
6inarow
Originally Posted by Ganey
True.
6inarow
Love all the 6's. but I bleed 216/235/261 and the Jimmys
Old Oct 20, 2011 | 10:55 AM
gkull's Avatar
gkull
Over on Digital Corvettes is a guy by the post name of GRT1999 or something like that. Anyway he has a side business of doing our Vette steering boxes and rear ends. he posted a step by step rear end rebuild. I drilled, tapped and installed a hex plug on the lower left side of my rear end housing. Not the rear end cover. I was actually going to put in a rear end oil cooler, but did not.
I use 85W-140 Valvoline syn power. I can't say that I swear by it because you would have to do back to back testing under the same conditions with a Dino gear oil. I do know that my 20 year old 4.11 richmond ring and pinion were still looking brand new. My custom hardened yokes looked brand new. My Tom's Stage 8 posi unit was so physically warn out that it went in the garbage. It was only 4-5 years old. I rebuilt my rear end with 3.55 gears and drilled for a drain plug.
Old Oct 20, 2011 | 11:45 AM
Jeff_Keryk's Avatar
Jeff_Keryk
Sucking the RE lube out sucks.
Old Oct 20, 2011 | 12:02 PM
joewill's Avatar
joewill
sure, if you have it apart for other reasons .. or want to have that option if you abuse the rear end, then a drain plug might make sense.
Old Oct 20, 2011 | 12:13 PM
bluthundr's Avatar
bluthundr
Seconded
Old Oct 20, 2011 | 12:24 PM
gkull's Avatar
gkull
I for one don't agree with this statement. The problem is with the soft metal stock Yokes. I bought my 79 Vette new and in less than $50K miles on the OD the yokes ends had worn down past the snap rings. It filled the gear oil full of metal flake and destroyed the rear end. Our Rear ends are a POS right from the factory built with substandard parts.
I might have abused mine a little though.
Old Oct 20, 2011 | 12:56 PM
Marlin's Avatar
Marlin
Yea the only reason I would do that is if I was racing or the diff was known to have issues. I have never heard of any factory issues with the Diffs in C3's. That and even the basic dino stuff was good for 100k in most let alone the Syn options out there now.
Now my Nissan Titan diff has a drain plug but titan trucks are known to have bad diffs. So in that case a drain was a good thing.
Old Oct 20, 2011 | 05:43 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
With George. These have metal disc clutch packs and the side yokes wear on the center pin. They are full of metal shavings if they have never been serviced and these shavings are death to the roller bearings in there. I would recommend a fluid change at least every 30,000 miles or 5 years. Pretty cheap to change the fluid and yes, it really is a PITA to draw the fluid out through the fill hole. I would worry about drilling and tapping the case with a high HP application though.
Old Oct 21, 2011 | 07:03 AM
Danish Shark's Avatar
Danish Shark
50K miles will still take quite some years unless it's a DD
Old Oct 21, 2011 | 09:47 AM
Red 69's Avatar
Red 69
If you decide to install a drain, it is not very difficult. If you have any miles on it, the bottom of the case will have plenty of crud on it. I'd recommend pulling the cover and cleaning well before adding fresh lube and doing this.
Back a few years, GTR1999 posted a differential rebuild procedure in which he described installing a drain. I followed suit and placed this one. Don't go all the way with the NPT tap, ideally, you want the collar to be flush on the inside. This will allow most of the lubricant to drain when you remove the plug. Locate the hole where there will not be interference from any brackets.
[IMG][/IMG]
Old Oct 21, 2011 | 11:29 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
WOW "red" you need to take that car out and get a little dust on it! It's so clean
I cleaned my diff only cause I took it out ,it was leacking fron the side yoks, but the inside was nice and clean 65k on it .Ron
Old Oct 21, 2011 | 02:57 PM
wan2run's Avatar
wan2run
While I had the diff out I drained, repainted, put a new gasket, and put new fluid in. While I was there I decided to put the drain plug in as well. No longer need to remove the cover to change fluid...
To thoughts on differential drain plug
Old Dec 22, 2011 | 04:45 PM
corvettesummer79's Avatar
corvettesummer79
Default 79 L82 rear end gear oil fill hole
I wanted to make sure my 79L82 has enough gear oil in the rear end
can anyone please tell me where the fill hole is? I looked and didnt see
a place to pour some in. thanks
Old Dec 22, 2011 | 04:50 PM
MelWff's Avatar
MelWff
it's on the passenger side of the rear, a square headed plug.
Old Dec 22, 2011 | 05:24 PM
gcusmano74's Avatar
gcusmano74
If you are going to drain and refill, and you have a limited slip diff, don't forget the posi additive. They were all posi, starting in maybe 72.
If all you are doing is topping it off, not important. Just start out with the diff cold. Hot diff fluid expands, and if the used fluid spills, and gets on your clothing, the only thing that will remove the oil stain is scissors!
