Ignition switch replacement
Old Oct 21, 2011 | 11:12 PM
Dmossy96's Avatar
Dmossy96
4th Gear
Default Ignition switch replacement
Im looking for pictures to reassemble the ignition switch for my 81 corvette.
Old Oct 22, 2011 | 12:34 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Ok.. hard one to call here.. Some call the switch in the column you put the key in the ignition switch.. but this is actually the cylinder and case. The ignition switch is actually at the bottom of the steering column and held in place by two screws.
Are you working on the ignition switch or the case and cylinder?
Post back and I'll see if I can help you.
