Clock Knob - 1969 Corvette
Old Oct 25, 2011 | 06:08 PM
edfrye's Avatar
edfrye
Default Clock **** - 1969 Corvette
Does this **** unscrew? If so - clockwise or counter clockwise. **** pushed all the way in? I tried the foregoing counter clockwise with the **** pushed in. Thanks Ed
Old Oct 25, 2011 | 06:46 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Remove the center screw from the ****, with a small flat blade screwdriver.
Old Oct 25, 2011 | 09:29 PM
edfrye's Avatar
edfrye
Default Thanks for the message below.
As you know, it worked thanks. I dropped the screw behind the panel so now I have to find it. I tried a magnet with no luck. If I don't find it what size is the screw or what is the part number? Thanks again
Ed
Old Oct 25, 2011 | 11:15 PM
gbvette62's Avatar
gbvette62
It's really not a screw, but instead it's an internally threaded "socket", with a slotted screw head.
I have no idea what size it is, and the only way that I know you can buy one, is in the sets that comes with the **** and the screw (actually the set comes with 2 different length ***** and the screw).
Old Oct 26, 2011 | 10:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by edfrye
...I dropped the screw behind the panel so now I have to find it. I tried a magnet with no luck...
Save yourself the frustration of the search. Order a replacement **** and screw kit.
At some future date when the original screw shows up, keep it as a spare.
Old Oct 26, 2011 | 11:06 AM
Surfer69's Avatar
Surfer69
I was messing with this also recently and was wondering is the chrome **** suppose to sit outside the hole in the console or nest right into it? Mine sticks out a bit and I think it looks wrong.
Old Oct 26, 2011 | 12:02 PM
Easy Mike's Avatar
Easy Mike
The **** is on the end of the clock stem. It will not necessarily be up against the bezel, but it also should not be sticking too far out. If yours is way out, it's possible the wrong clock stem was installed by a PO (there's a long and short stem).
Old Oct 26, 2011 | 06:06 PM
Alan 71's Avatar
Alan 71
Hi,
Originally there was a short black plastic 'sleeve' that slid on to the clock's shaft before the **** went on and the screw went on. It's about 1/4-3/8" long and fills the gap between the **** and the face of the gauge bezel.
It's shown as an item in the AIM.
Regards,
Alan
Old Oct 26, 2011 | 06:07 PM
edfrye's Avatar
edfrye
Default Thanks
Old Oct 26, 2011 | 07:30 PM
boltnut's Avatar
boltnut
Originally Posted by Alan 71
Hi,
Regards,
Alan
Dang. Alan is a fountain of info. My clock is missing the plastic bushing too. Would have never known.
I wish Alan could come look at my convertible top and tell me why it isn't kosher.......
Old Apr 21, 2021 | 01:00 PM
teneck83's Avatar
teneck83
Hi,
Regards,
Alan
I understand this is an old post. Any idea where to pick up the clock shaft sleeve? Original or repro?
Old Apr 21, 2021 | 02:58 PM
7T1vette's Avatar
7T1vette
Use an appropriately sized length of black heat-shrink tubing.
Old Apr 21, 2021 | 10:00 PM
teneck83's Avatar
teneck83
Thank you.
Old Apr 21, 2021 | 11:34 PM
teneck83's Avatar
teneck83
https://omicronclock.auctivacommerce...-P5820560.aspx
To Clock Knob - 1969 Corvette
