Afterfire- Real bad
Old Oct 25, 2011 | 08:43 PM
hardhat273's Avatar
hardhat273
Default Afterfire- Real bad
My C2 1966 427 is after-firing through the exhaust something horrible. It starts to buck like when a car slows down and you don't throw in the clutch. Even when I have enough speed or am accelerating, it after-fires through the side pipes like a machine gun especially when I let off the accelerator. I rebuilt the carb and set the timing and the after-fire went away. I only drove it a few miles after I timed it and then put it away. The very next time I took it out it started doing it again.
This one has me and my friends baffled. We feel it is Fuel, air or vacuum. Anyone out there with suggestions?
Old Oct 25, 2011 | 09:53 PM
Roco71's Avatar
Roco71
I went through this last month. Vacuum leaks or leaks in the exhaust are often the problem. Mine was a bad plug not burning the fuel in the cylinder and igniting it in the exhaust.
Old Oct 25, 2011 | 09:54 PM
kf4cln's Avatar
kf4cln
I thought I was going to see( God forbid ) a burnt up corvette after pix
Old Oct 26, 2011 | 12:43 AM
hardhat273's Avatar
hardhat273
Default Thanks for the help.
I have been reading a lot of posts on this site. Looks like I came to the right place. I will put her on the lift tomorrow and check the exhaust. I will let you know how I make out. Thanks for the replies.
Old Oct 26, 2011 | 01:43 AM
Peterbuilt's Avatar
Peterbuilt
Default Welcome!
I might try a new set of points, check the dwell and timing and go from there.
A little more history like: what carb, any other mods and such will help.
And by the way you posted on the C-3 Tech Forum, but thats OK!
You'll get help on this question here too!
Old Oct 26, 2011 | 09:02 AM
njfl's Avatar
njfl
You mentioned that you rebuilt the carb and set the timing and the problem went away...then came back.
You didn't mention if you checked the timing after the problem returned.
Consider that your distributor hold-down could be faulty, causing it to rotate and mess up timing or your points could be moving.
Old Oct 26, 2011 | 09:27 AM
TERRY CLARK's Avatar
TERRY CLARK
Bad coil !
Old Oct 26, 2011 | 12:26 PM
69 Chevy's Avatar
69 Chevy
Originally Posted by hardhat273
...it after-fires through the side pipes like a machine gun especially when I let off the accelerator.
That's distinctive, leave it that way. You'll be the talk of the town.
To Afterfire- Real bad
