Fast idle delete ?
Old Oct 26, 2011 | 08:28 PM
boltnut's Avatar
boltnut
Default Fast idle delete ?
Why do I need my car to do a high fast idle on startup for a minute or two ? Couldn't I just adjust the choke so I start on "medium" idle and wait a
little longer ? Having a car start cold and idle so high seems contradictory to me. I thought you should not "rev" an engine till warm.....just curious because right now my idle is set lower and seems fine if not a little rich when stone cold.
Old Oct 26, 2011 | 08:45 PM
Alan 71's Avatar
Alan 71
Hi BN,
I Don't know.
Is there some advantage to the oiling system to have the fast idle, and perhaps some advantage to bringing the engine to operating temperture quickly?
Regards,
Alan
Old Oct 26, 2011 | 08:51 PM
Mike Ward's Avatar
Mike Ward
Cause it won't run worth a cr*p if everything is at factory spec.
Old Oct 26, 2011 | 09:17 PM
boltnut's Avatar
boltnut
Wouldn't that statement only apply to how it ran at cold idle ? I don't understand ? After it warms it would all be the same ?
Old Oct 26, 2011 | 09:23 PM
Mike Ward's Avatar
Mike Ward
Well, yes but I simply answered the question you asked................
Old Oct 26, 2011 | 09:28 PM
boltnut's Avatar
boltnut
Originally Posted by Alan 71
Hi BN,
I Don't know.
Regards,
Alan
My race engine background (limited admittedly ) tells me high RPMS at cold idle is not good. Better to wait til warm ? I have been wondering if a diesel engine block warmer is not a bad option. I have my car set up for performance and it suffers at idle so maybe it's not a bad idea. Mind you I have not done even basic research into block warmers.....seems like it would be much less wear on engine parts than high idle....
Old Oct 26, 2011 | 09:30 PM
boltnut's Avatar
boltnut
You've never cranked that baby up stone cold to a 1500rpm idle and wondered......"is this good ?"
Old Oct 26, 2011 | 09:34 PM
boltnut's Avatar
boltnut
It just kinda reminds me of some guy you hear get in his car when it's stone cold and rev the thing a bunch for whatever reason he thinks he has. Warm up, sound mean whatever. I thought it was best to be cool until that girl was ready. Maybe I'm wrong ?
Old Oct 26, 2011 | 10:22 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I have the fast idle adjusted much lower than factory on all my Vettes. Just turn it down.
Also I adjusted the chokes. At the time I did this the outside temp was about 50 degrees out. With the motor cold I turned the choke housing with the thermostatic spring inside to where the choke JUST closed.
Before it was kinda beyond closed, where it had to warm up a bit before it even started to open.
Besides, I never drive em when it's real cold out.
Old Oct 26, 2011 | 10:23 PM
Mike Ward's Avatar
Mike Ward
50ish years of manufacturing SBCs taught GM that they're not fragile pieces of glass that shatter if someone f*rts. They were built to be cold started at minus whatever degrees, be tossed immediately into gear and driven for 150K miles in between overhauls with a minimum of care and maintenance. I think they got it right.
Old Oct 27, 2011 | 05:56 AM
boltnut's Avatar
boltnut
Ok. I hear ya. I guess just false concerns. I've never really played with a stock setup. The first thing I always did was pull all the gizmos off and try to go faster at all costs.....while pondering the OE setup it just seems excessive to idle that high when cold. Or was that just an engineering compromise to make the driving experience easier for the consumer ? Compromises are made all the time.
Old Oct 27, 2011 | 05:59 AM
boltnut's Avatar
boltnut
That's kinda what I did. How long does it take your choke to pull off all the way ? Qjet ?
Old Oct 27, 2011 | 08:02 AM
noonie's Avatar
noonie
You got it, grandma and the like had to use it too and knew nothing about carbs and chokes and just wanted it to go in all kinds of weather.
My new FI computer controlled engine idles at 650 rpm after starting in all kinds of weather. It took computer engine management to finally get it right.
In S Florida, I have the butterfly adjusted wide open, cold (no choke), starts with 2 pumps and has to be feathered a bit for 15 seconds and then will idle at 800 rpm in neutral. Usually wait 5 minutes before driving.
I don't like the factory set choke on high idle either.
IMO, block heaters are always good, as are accumulators, but I don't bother with them. If it was a Maybach, then maybe.
Old Oct 27, 2011 | 02:46 PM
qwank's Avatar
qwank
My car has the factory high idle still. It works great. It starts the first time every time. I let it run for about 30 - 60 seconds on high idle. tap the gas to bring it down and go!
Old Oct 27, 2011 | 02:51 PM
gcusmano74's Avatar
gcusmano74
What he said.
I adjust my 74 small block to factory spec. I can start it in 20 degree weather and drive it right away. I "balloon foot" it till it is fully warm. Remember, any time you are idling, you are getting 0 miles per gallon.
Actually, due to the inefficiency of a cold engine, a cold idle speed, correctly adjusted, is just about the same as a warm idle speed, anyway.
If the stock fast idle setting seems too high for your car, shave it 100 RPM at a time untill you are happy.
Old Oct 27, 2011 | 03:24 PM
scottyp99's Avatar
scottyp99
Most of the carb books that I have read give a theory that the high initial idle speed increases oil pressure while cold, and gets a little more airflow thru the carb in order to help vaporization while cold. I like to set my high idle around 1200-1300 rpm, I don't think that will harm the engine much more than idleing at 700-900 while cold. Just don't zing it up to 6 grand before it can even get oil sucked up into the pump!!!!
Scott
To Fast idle delete ?
