Leak-down Test
Old Oct 27, 2011 | 11:10 AM
gnkjoy's Avatar
gnkjoy
Default Leak-down Test
Doing a leak-down test on my 71 350. With the crank timing alignment mark @ 0 degrees, number 1 & 6 cylinders would be @TDC. If I rotate the crank 90 degrees does this put #8 & 5 @TDC? Then another 90 degrees #4 & 7 etc?
Old Oct 27, 2011 | 11:20 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i can never do it that way becasue i cant remember it.... my easy way to do this is to mark the distributor base at the bottom of each spark plug tower and then take the cap off and turn the motor so the rotor is pointing to the next mark and follow the firing order around the engine...
Old Oct 27, 2011 | 11:56 AM
zwede's Avatar
zwede
Yes, but one of them is in the overlap phase (valves slightly open) and won't build compression.
You need to do each cylinder in the firing order and rotate the crank 90 dgr each time.
Old Oct 27, 2011 | 02:42 PM
gcusmano74's Avatar
gcusmano74
If you have a manual trans car, and no timing tape on the harmonic balancer, you can raise the rear wheels, and with the car in top gear, use the orientation of the u joints on the driveshaft to determine when you have moved the crank 90 degrees. If the plugs are out, it won't be too difficult to turn the engine by turning the rear wheels.
I know, it's a Bubba way, but it works in a pinch.
Laugh and enjoy a beer afterwards. Unless you found out by your leakdown that the engine needs work. Then you can cry.
To Leak-down Test
