Braided Fuel Line
Old Oct 30, 2011 | 06:32 PM
rod7515's Avatar
rod7515
Default Braided Fuel Line
Was wondering what is the cleanest easiest way to cut braide fuel line for tucking it into the line swivel. Tried a hacksaw and a buzzer wheel cutter but not great success. Does it help if I wrap the area to be cut in tape first?
Rodney
Old Oct 30, 2011 | 06:36 PM
V8Ranger's Avatar
V8Ranger
Yes. Wrap masking tape tightly around the hose (2 or 3 wraps) centered where you want to cut. Use a composite cutoff wheel, made for cutting steel. It will stink but will work good. Clean the hose out well after. Also, use oil on the hose and fitting during assembly.
Carl
Old Oct 30, 2011 | 08:16 PM
damoroso's Avatar
damoroso
Most local parts stores that make hoses can cut it for you. If there's a performance shop nearby, they usually do it too. That's the easiest and cleanest way I've ever found to cut braided hose.
If you do it yourself, V8Ranger has some good advice. I'd add, use a hose clamp as a cutting guide to make sure you get a straight cut.
Old Oct 30, 2011 | 08:31 PM
redvetracr's Avatar
redvetracr
duct tape and a 32t hack saw is all I have ever used.
Old Oct 30, 2011 | 08:35 PM
KENS80V's Avatar
KENS80V
I found filament tape to be the best to use with a cutoff wheel.
Old Oct 30, 2011 | 08:41 PM
khubert035's Avatar
khubert035
I use some wide electrical tape -buddy called it 200 mph tape (we watch lots of NASCAR). Mark the center, cut around slowly- I use a dremel tool cut off wheel. if any part is frayed, retape.
Old Oct 30, 2011 | 08:43 PM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
I use a block of aluminum and a very sharp scaling chisel.
Whack the chisel smartly and the line will cut cleanly. I stopped using tape because every time I peeled it off, it would open up the braids.
Old Oct 30, 2011 | 09:04 PM
billla's Avatar
billla
St. Jude Donor '14
Carl
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
If you're planning to cut a lot of braided lines, then do what I did and buy a braided hose cutter from Summit Racing for $42.00
Old Oct 30, 2011 | 09:14 PM
rod7515's Avatar
rod7515
Thanks for all the replies, Tomorrow night if I have electricity again (snow storm knocked it out) I will give it another try.
Rodney
Old Oct 31, 2011 | 01:27 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I just use and electrical cable cutter I got from Lowes. It was made by Greenlee. Now one thing I will say is all hose is not equal. The cheaper hoses from Jegs and Summit brands are a mess to cut regardless of method used.
Old Oct 31, 2011 | 06:37 PM
Richard454's Avatar
Richard454
The tape method also gets the braided line all sticky when it gets heated up but the cutoff wheel- makes it real tough to slide on the fitting...
Here's a video- I can guarantee you will not use tape again...
Richard
Old Oct 31, 2011 | 10:30 PM
MyRed69's Avatar
MyRed69
I could never make the tape trick work, it always frayed too much. Just after I tried for the final time with the tape I saw the 2X4 laying on the bench i used to hold a piece of steel i was cutting/bending earlier; I used a hole saw to cut a hole just a hair undersized of the piece of steel, split the 2X4 and clamped it in the vice.) I thought that just might work for the hose too... I drilled a smaller hole in another 2X4 to fit the hose, split the 2X4, clamped the hose in the 2X4 and the vice, cut it with the wheel, and presto, nice clean, straight cut. It slipped right into the fitting with a little help from a coke can i cut up, wrapped around the hose and used as a 'funnel' to guide the hose into the fitting.
I guess I should have taken some pix...
Old Nov 1, 2011 | 02:12 AM
Korevette's Avatar
Korevette
Black electical tape wrapped 4 times, a 1/16" high speed cut off disc, unwrap the tape, clean with lacquer thinner, lube with ATF, insert into fitting, press hard and then start nut with AFT lube to prevent stripping of threads.
Experience - Found leak in starting line going into second round, oil down bought time, went to semi finals.
Old Nov 1, 2011 | 02:35 AM
Rebelrob's Avatar
Rebelrob
YES to this. I had never cut a braided line before, and the chisel worked perfectly. Clean and fast. One whack.
Old Nov 1, 2011 | 10:49 PM
wheatpj's Avatar
wheatpj
Greenline model 727 wire cutter. They are for cutting thick gauge electical wire. Got them at Lowes...inexpensive. Tape the braided line first and cut. Very clean cut.
Old Nov 1, 2011 | 11:24 PM
rod7515's Avatar
rod7515
Just got the power for the house back tonight. Hope to give it a shot tomorrow. Thanks for all the suggestions.
Rodney
Old Nov 2, 2011 | 12:32 AM
Solid LT1's Avatar
Solid LT1
The way I was taught by a guy who worked with Carrol Smith. If you don't know who CS is, you should find out quickly before playing with "race car" stuff on your C3.
To Braided Fuel Line
