sequence advice
. I planned to effect the rear channel repair, paint stripping and clip removal, while the body is still on the dolley. The doors were already off the car and hinges not marked, before removal, when I got the car. Once these steps were taken, and the tub prepared, I was going to set it back onto the chassis, and try to assemble the doors and the front clip from that point. Is it possible to do that way? Any info is appreciated. One more question about mounting tub to chassis. Body is a 1971, frame 1973. I have decided to use the 1973 poly mounts. Do these mounts still require shims like the 1971, if so, how? Any info is appreciated.You will have to shim them to get the rear edges of the doors to line up nicely with the body.
But first you have to address all your birdcage issues.
Good luck, buddy. That's a bunch of work in front of you. I did mine last year. Whew.
i would set the doors, drop the body and shim as needed, and then remove the front clip and make all the repairs. then you can lift the body if needed in order to repair the rocker channels and you know everything will fit.
I'll speak to the shim aspect.
I believe I'd put 3 shims on each mount and then place the body. That way you can add or SUBTRACT shims as necessary to obtain the gaps you want.
I've seen very few pictures of chassis with mounts with 0 shims or more than 5/6 shims.
Remember the shims were added before the chassis ever met the body that it would hold; the shims brought the mount height to a certain tolerance and weren't used to adjust the gaps at St. Louis. Restorers use the shims to adjust the mount height based on the gaps we see. Just backwards of what St. Louis did.
Good Luck!!!
Regards,
Alan
I believe the same body mount shim was used from 63 through 82.
Regards,
Alan
I love trivia...
the frame was upside down when it was fixed to the jig to measure the body mounts. The worker wrote the shim count numbers UPSIDE DOWN so when the frame was flipped at the start of the the chassis line the numbers were correct for the worker placing the shims.
