1969 Front Tire Rub
http://www.corvettefaq.com/c3/MoreBite.pdf
I may end up having to purchase some new front tires when its all said and done. I was hoping I might find a way to give me just a little more clearance in the front some how and keep my current tires.
Thanks again.
If it's limited by the steering arm, maybe just need to adjust the tie-rods over to the left 1/2 or one turn and recenter the wheel
Not something I've played with as of yet so I'm probably wrong.
Mooser
Edit
I remember reading somewhere that the later vettes with the 255/60 optional tires needed to have the bottom front and back of the front fenders trimmed for clearance. I don't know this for sure, only what someone else wrote and since the 69 didn't have the flare it may not be relevant
The issue you are having is one we had today. We installed 235-70 R15's firehawks on a 1971... they rub.
The original size tire were a F70x15 on all 1969-72 cars... or converted.. 215/70R15
The issue that going wider brings.. Say... for example the tires we tried to install today: The original tread width was 6.75" The firehawk 235 is 7.25". The diameter of the tire is also .25 taller than a normal 235 radial... (we measured a new eagle gt today, same size different diameter) What this means is that you have .50" wider tread or .25 further out. Add this to the .25 larger in diameter and you have tire rub.
I have 235-70-r15's on my 72 and never noticed until today that I have about 1/8" between both fenders when I turn the wheel. Way to close for my liking so I'll have to change these soon.
So..combine this with what others above have mentioned, throw in a little body mount bushing wear, possibly some other busing wear and you have an invite for a major issue.
How did we solve the problem today? We ordered 215x70xr15 firehawks. They are about 1/2 inch less in diameter and should clear just fine.
Tire size conversion chart ----> http://www.tirerack.com/tires/tirete...sionchart.html
IMHO
Willcox
