Upper Control Arm bent (Use or Replace)?
Old May 6, 2002 | 07:13 PM
Ybnormal's Avatar
Ybnormal
Default Upper Control Arm bent (Use or Replace)?
While I'm replacing my control arm bushing I was checking them for straightness. I noticed that the upper aft end of the LF control arm is bent approx. .060". Is this still useable or should I replace?
YBnormal...drive a vette
Old May 6, 2002 | 08:56 PM
78Vette-SA's Avatar
78Vette-SA
Default Re: Upper Control Arm bent (Use or Replace)? (Ybnormal)
Hard to say without seeing it but that little bit could proably be adjusted for with a good alignment as long as the integrity is not compromised. When in doubt though.
Chances are it was probably like that for a long long time. Assuming the car drove straight, you're probably ok.
Old May 6, 2002 | 09:00 PM
DavidOrr's Avatar
DavidOrr
Before I became smart enough to add the braces while pressing out my bushings I bent one of my uppers as well. Threw it back in and have not had any problems.
I don't remember by how much it was bent though. Seems to me mine was more than .06"
Old May 7, 2002 | 09:52 AM
mayberg's Avatar
mayberg
I'd love to have control arms that close to spec. I suppose that when you torque the bushing end caps against the shaft, all will be OK.
To Upper Control Arm bent (Use or Replace)?
