Another Headlight issue
Old Nov 17, 2011 | 02:37 PM
Vetteman25's Avatar
Vetteman25
Default Another Headlight issue
Per Corvette-101.com instruction and diagram. Hoses are fairly new. Connections are good. Line pressure is good.
Situation - Left headlight opens/closes perfectly fine. Right Headlight is stuck in the open position and will not go down.
Trending - Over the past three weeks the right head lamp has delayed much longer too open and close.
Solution - Common sense has led me to believe it is the actuator or relay.
Anyone want to chime in and agree or no? Thanks!
1972 LS5:
Old Nov 17, 2011 | 04:19 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
I'd guess relay. Does it open if you close it manually and then turn on the headlights? If not, then the actuator seal is bad. Easy fix with the right seal kit.
Old Nov 17, 2011 | 04:44 PM
Vetteman25's Avatar
Vetteman25
The right headlight is stuck open. Does not open or close with the manual pull down switch under steering column
Old Nov 17, 2011 | 05:33 PM
Alan 71's Avatar
Alan 71
Hi V,
Have you reached the mechanism from underneath to try opening and closing the headlight by hand?
Is it possible that it's gotten 'locked' in the open position because the 'knee' is out of adjustment?
You can pull down on the 'pin' the 4 springs fasten to in order to close the door. The 'pin' is in the center of this picture. Don't pull on the plastic switch; it's pretty fragile.
Once you free it to move perhaps you'll be able to determine the problem.
Good Luck!
Regards,
Alan
Old Nov 17, 2011 | 05:46 PM
Vetteman25's Avatar
Vetteman25
thanks..ill give that a shot when i get home.
Old Nov 17, 2011 | 06:48 PM
Vetteman25's Avatar
Vetteman25
ok that worked..it was stuck...the actuators are still very slow and out of sequence. Not that is any surprise but perhaps changing the actuator seals may assist in there struggles...Thanks very much
72 LS5
Old Nov 18, 2011 | 06:23 PM
TNX ZORA's Avatar
TNX ZORA
In over a 100K mi. on our '73 the only headlamp bucket failure has been the actuator seals. Once replaced it was like a new car. Hoses, etc., all original.
Old Nov 21, 2011 | 01:51 PM
78IndyPace's Avatar
78IndyPace
Maybe, maybe not. My sticky thread includes some system level troubleshooting checks you can do that should help isolate your problem(s):
How Your Headlight System Works
Old Nov 21, 2011 | 11:30 PM
Dave J's Avatar
Dave J
Vetteman, PM sent. I live across the county line from you. I can help you get those lights humming again.
To Another Headlight issue
