Rear rotor runout?
(The rears were not an issue with most cars back then, they had drums)
Your memory is going back a little further than mine. We're talking about cars that have disc brakes on all four.
(Same holds true for the C3 front rotor and spindle, riveted or bolted together )
I could maybe agree that there is some measurable rotor run-out involved with two piece spindle and hub flanges and rotors. But just as another note of experience, I have repacked my front bearings about every 3 years for the last 27 years. Each time making no attention to where the rotor is reassembled to my front hubs. Each time have never used shims and never needed to bleed the brakes after removing the calipers and suspending them temporarily on a hook without disconnecting the brake lines. My front calipers and rotors are about 15 years old and my rear calipers and rotors are over 25 years old. I put new rear wheel bearings in about 20 years ago. The one spindle is original to the car and the one I did replace. So there is quite a variety of parts there, from different eras and vintage. I drive the car as a daily driver every summer. So if your bearings are loose, or your rotor has too much run-out, fix them. If your spindle flange is bent, as one of mine was, replace it.
Can you tell me where to buy the shims to shim the rotors?
Thanks, Dave.
http://www.brakealign.com/
It is virtually impossible to machine new axles with any measureable runout. Any junior machinist can verify that.
My neighbor has a 150 grand cnc turning center and spits out high production parts to 2 ten thousandths all day every day.
The flanges are not that strong compared to other vehicles and as you mentioned will get distorted thru common use or possibly even by the original factory riveting process. You can check any axles or assembly with just "v blocks" and a dial indicator.
If your bearings are within specs, easiest is to use a proper "on car lathe" for the rear and a regular brake lathe that's in good shape for the front and not worry about the axles or hubs that much.
Glad to see you did it the right way though.
Thanks for wrecking that drive time for me ironcross
I don't know of too many machine shop lathes that you could just stick one of these axles in the chuck and be ready to go. (I've done it). Best is to use the original centers or make your own jaws for a large enough chuck to tag both bearing surfaces at once (different diameters).
It's futile to second guess GM's strategy, but it's obvious that the original spindles were machined between centers using a type of dog drive. It's still the best method, since it requires remounting in the lathe or dedicated machine, after rotor install, with no loss of accuracy.
This type of mount can assure runout of only a few ten thousandsth (known as tenths) .0001"
The rotor pad area may well have not even been machined at this stage, just the mating surface and holes. The riveting process may well cause runout on the spindle flange in itself. It doesn't take much, I can cause a couple thou with a hammer on a flange. With that in mind removal of the rivets and rotor by the common method of drilling the heads of and punching out the stem can cause runout.
The rotor pad area may have been machined for the very first and last time after being riveted. Just a cost effective manufacturing procedure, nothing more elaborate than that.
There were many axle manufacturers in the Detroit area an surrounding states, US, Southwest, BorgWarner, Skyway, NTK, Lafere, Eaton, Dana (Spicer), American, SG, etc. Gm probably used more than one or at least had a backup.
With the rather recent popularity in separate rotors, the runout problem is more popular than ever on almost all cars, mostly from rust, and sloppy repairs, hence the simple fix, on car lathe.
After just completing a body off resto, I have finally been driving for a few weeks and noticed a squeaking from the rears, now even tho I did check the run out it would appear from turning the hubs that there is considerable runout and the squeaking is indeed the pads moving back and forth across the locking pin.
So thanks to this really enlightening article I will try and address the issue, and of course will convey my results, your advice and help is appreciated.
https://www.corvetteforum.com/forums...out-shims.html
Jim
