Rear rotor runout?
https://www.corvetteforum.com/forums...out-shims.html
Jim
I set the rotor in position 4 for the Right Rear
Here are the measurements of the inner and outer edges of the rotor:
RR inner: 1/.013, 2/.012, 3/.011, (4/.010), 5/.011
RR Outer: 1/.016, 2/.018, 3/.16, (4/.014), 5/.015
The Left Rear is horrible!
LR Inner: (1/.016), 2/.016, 3/.016, 4/.017, 5/.016
LR Outer: (1/.022), 2/.023, 3/.023, 4/.024, 5/.023
This is by far he worst of the two but neither are great
There are a lot of mobile mechanics here that have the equipment to correct rotor warp in situ and this maybe another option to try and reduce the run out, the hubs were assembled with .002 set so they are pretty close.
The first thing is to get the rotors turned/trued up. Then you shouldn't have any difference between inner and outer readings.
Secondly, maybe I'm mistaken, but it seems like you are making this more difficult than it should be. Just take the best position and shim from there. So rotate the rotor to the position where the runout is the least and mark it and use alignment shims to correct that (as good as you can). On mine, I didn't check inner and outer, just outer and they are fine. And I have lip seal calipers.
So, get them turned, then put them on and get the runout the best you can, then shim them to be as good as you can get it. Use the tapered shims. In my case I had to use two on each side to get them to .002. I think I got the shims from rockauto.com.
Jim
Jim
