gas tank question?
Old Mar 3, 2012 | 10:18 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I recently took my vented 69 gas cap apart, because almost every 40 year old part is shot, by bending the crimped tabs you can dissassemble clean and inspect the vent/1 way valve which is just a spring loaded flapper valve, it had a ton of crap in it and probalbe was not working like it should. you can clean and rebuid the complete assemble.
Old Mar 3, 2012 | 02:04 PM
loup68's Avatar
loup68
Army
Hey guys, gasoline expands when it is heated. The vented caps are only suppose to let air in to replace the lost fuel. What happens when you open a gas can in summer? Wooosh right? I was a fuel handler in the army for 3 years.
Old Mar 3, 2012 | 03:37 PM
mffi115's Avatar
mffi115
Originally Posted by DEEPSEA70
Could I just remove the separator, return line, and canister, and just go with the vented cap in my 70. I am putting in a Walbro in-tank pump leading to an LS3 Fuel injection. Thanks.
Yes, that's what I did. Check my blog (link below) and scroll down through the older posts and you'll see the fuel system I built.
