hood latches
Old Nov 19, 2011 | 05:35 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Default hood latches
I know the hoods are a little different throughout the early years. But are they pretty much the same besides the latches? For example...coule I take the latches off of a '76 hood and put them on a hood that came off my '71(long aftermarket hood) so it would fit the '76 body?
Old Nov 20, 2011 | 09:10 AM
Alan 71's Avatar
Alan 71
Hi B,
Since the 68 through 76 latches were the same I'd think you'd be able to use them. The latch configuration didn't change until 77.
Regards,
Alan
Old Nov 20, 2011 | 12:52 PM
DZRick's Avatar
DZRick
Originally Posted by Alan 71
Hi B,
Regards,
Alan
I'm pretty sure the '68-E69 are different and the bolt holes don't line up on the other years.
Old Nov 20, 2011 | 01:09 PM
Alan 71's Avatar
Alan 71
Hi DZ,
I took another look and I believe you're right! I lumped everything before 77 together.
Sorry b!
Regards,
Alan
Old Nov 20, 2011 | 01:20 PM
gbvette62's Avatar
gbvette62
The male and female hood latches used in 68-69, are different than 70-76 latches.
You should have no problem using 71 latches, to install the hood on a 76 Corvette.
Old Nov 20, 2011 | 02:34 PM
Bruthish's Avatar
Bruthish
nice I hope so! I don't want to fork out the $$$ on a new hood if I could use one I already have! Thanks for the input!
Old Nov 20, 2011 | 09:57 PM
gbvette62's Avatar
gbvette62
The 70 through 76 latches are interchangeable, but the hood itself, may be different. The rear edge of the 71 "long hood", may not line up with the back edge of your 76 fenders.
The 71 fender tops are shorter and flatter, where they meet the windshield, than the 76 fenders. The 71 fenders had a molding on them, at the base of the windshield, so the fender is flat on top. This molding lined up with the molding on the back edge of the wiper door. Long hoods made for 68-72's, have a flatter rear edge than 73 and later hoods, to properly meet the fenders.
The 76 hood has a "flare" at the back edge, to clear the wipers, and the 76 fenders have a flared edge, to me the hood.
Old Nov 20, 2011 | 11:34 PM
DZRick's Avatar
DZRick
Hi DZ,
Sorry b!
Regards,
Alan
I only knew because I had to deal with mismatched latches for my '68. You have so much knowledge about these cars it's a little scary, Alan and now that you got yourself a camera, your like a book!
To hood latches
