I know I know headlight relay valve question
To test your relays: With engine running connect a hose to the small port on the relay and suck on it. If the headlight closes the relay and actuator are good.
Use this link to verify all the components vacuum troubleshooting. I just rebuilt my relays. I agree, $200 is a lot!!! Rebuilding doesn't cost much, so what do you have to lose. In my case, the diaphram worked fine, so piston was moving up and down as it should. Problem was the rubber piston was not making good enough seal to "switch" the vacuum between ports. I took two approaches; on the first one, I used a dremel to cut the binding ring off to separate the two halves of the relay. Cut and remove carefully because you are going to reuse these. Cleaned everything up good and hit the metal top with a fresh coat of paint. Then I repaired the rubber piston. You have to remove the piston from the shaft; the end is stamped to hold the washer on the shaft, carefully remove enough of the metal until you can slide the washer and piston off the shaft. If you look at both ends of the piston, they are really just cups. Buy a couple of o-rings that will fit in the cups, just big enough to slightly spread the cups outward (sorry I don't remember size), you can get these in the plumbing section of the hardware store. I used weather strip adhesive to secure them. Then put everything back together. Use vasoline to lube piston before reinserting. I used JB Weld Steel to secure pison back on shaft (I broke end of shaft when trying to recrimp the shaft end
). The binding ring can be soldered on, but I used the JB Weld Steel again to secure since I didn't have the right setup to solder. On the second one, I did not cut the binding ring. I just removed metal from shaft end and slide the pison out. Cleaned, painted, repaired piston, lubed and then JB Welded the piston back on shaft. The first one works perfectly. The second one still had a slight leak. After tearing it back down, I found that one end of the piston (the cup) had dry rot and cracked. Now I just need to find another piston.
Anyone know where I can source just the rubber piston?
This will give you and idea of the process. Not hard at all. Do an advance search on vacuum relays and you'll see a lot of info and different ways the repair has been done.
http://forums.corvetteforum.com/c3-t...ay-valves.html
http://forums.corvetteforum.com/c3-t...tem-works.html
On the other hand, I have bought electric motors from a saturn, headlight control module from a firebird and the headlight motor mounting kit from 69myway. I just have not taken the time to do hardly anything to my vette in the last couple of years. I have cleaned it up a few times and driven it about 500 miles each of the last summers.
I tried rebuilding the relays but had no luck and ended up buying new ones.
Now everything works properly.
Sorry Cherokee, didn't mean to highjack your thread.
http://willcoxcorvette.com/product_i...ducts_id=26643
