How much MPG do you get?
Old May 7, 2002 | 06:53 PM
zwede's Avatar
zwede
Default Re: How much MPG do you get? (pats406nitrovette)
10-11 city and 15 highway. This was running on 7 1/2 cylinders as my cam was slowly grinding its way into oblivion. Still not too bad for a 454, IMO. EPA rating for mine was 8 city, 11 highway.
Old May 7, 2002 | 07:33 PM
MasterDave's Avatar
MasterDave
Moderator
Default Re: How much MPG do you get? (American Boy)
Lessee, it's not good, but that isn't way I got it. ;) I drove 200 miles on a cruise last summer ranging from 60 mph freeway speeds to 30 mph cruising. I figure 10 average and much less at anything with the expression...'YES'... in it. :D
Old May 7, 2002 | 07:53 PM
Larry B.'s Avatar
Larry B.
I went from Orlando to Sarasota for the St. Armand circle show. 134 miles. .....11 gallons of AMOCO 93 so that's ... A...er..A . er.... you do the math :cry It's fun though...
Old May 7, 2002 | 08:03 PM
Jester69Stingray's Avatar
Jester69Stingray
Default Re: How much MPG do you get? (silvervetteman)
I get 16 driving 60mph on the highway and about 8-9 driving 75. I dont know about around town my odometer doesnt work.
Old May 7, 2002 | 08:34 PM
American Boy's Avatar
American Boy
Default Re: How much MPG do you get? (Jester69Stingray)
Overall, I think that I won't improve much without compromising the power. Maybe some headers and mufflers would help make it more efficient. All my mods are in the way of power first and economy after. These cars where made to be driven. So step on it. :D
Burning gas is so fun. :jester
Steph
Old May 7, 2002 | 09:09 PM
joe73vette's Avatar
joe73vette
I consistently get just under 15MPG with my 350/TH400 3.08 rear. That is mostly highway diving, 75MPH and 60MPH in the speed zones. I am considering changing to a 700R4, which I read adds about 2MPG. When I first got the car, I drove about 70 on the highway, and got 15MPG even. Joe
Old May 7, 2002 | 09:18 PM
Racer16k's Avatar
Racer16k
I get 18mpg on the highway with 4.56 and 700r4. Not sure what I get in the city, never checked.
Old May 7, 2002 | 09:28 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
I think, for normal driving styles, your mileage is right on target.
But it's like Taijutsu said--driver habit is everything. I've seen 24 with my 77 L-48, 3.08 gears, TH-350. But I've also seen lows of 17. I rarely beat on the car. I have a very light throttle foot, look far ahead and coast to lights..basically, I drive like old people screw. And that's why my mileage is so good.
What my mileage will be with the new engine? Who knows. Probably the same, maybe better, as I expect it to be more efficient.
Old May 7, 2002 | 10:53 PM
73-454's Avatar
73-454
("34 degrees mecanical at 2500 RPM and 55 degrees total at the same RPM")
What are you talking abought 55 degrees total and this thing runs, That seems impossible so you are saying that the plug fires at 55 degrees before TDC Your pistons and valves must be fried by now.
Old May 7, 2002 | 11:05 PM
American Boy
Default Re: How much MPG do you get? (73-454)
Not at all,
The mecanical advance work with the engine RPM and the vacuum advance work with engine load.
If you floor it, lots of air/gas in the combustion chamber so it burn quickly and the vacuum advance don't give you any as the vacuum is down so you have only the mecanical advance.
When coasting, little air/gas in the combustion chamber so it take more time to burn completly. The additional retard that give the vacuum advance as the vacuum is up help to burn all the mixture.
Stephan
Old May 7, 2002 | 11:37 PM
WeasleVette454's Avatar
WeasleVette454
The WeasleVette gets around 10 to the gallon. Maybe 12 on the highway if I'm lucky. But instead of miles per gallon...FUN per gallon should be the question.
In that case...the WeasleVette gets aroound 100 FPG!! :yesnod:
Weasle :cool:
Old May 7, 2002 | 11:41 PM
73 LS-4's Avatar
73 LS-4
I think I got 12mpg last weekend going to the car show, I think a big thanks goes out to Lars for that one since I never got that before he rebuilt my quad, not bad for a 454 with 3.36's.
:cheers:
Pat Kunz
Old May 8, 2002 | 07:41 AM
  #33
groovyjay's Avatar
groovyjay
5MPG... on a good day 8MPG :lol:
Old May 8, 2002 | 07:55 AM
  #34
Sean Willard's Avatar
Sean Willard
Default Re: How much MPG do you get? (groovyjay)
11 city 14 HW with 3:70's and a 650 holley.
:cheers:
Old May 8, 2002 | 08:28 AM
  #35
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
The best I've got so far was 16.5 mpg (on a longer trip). Usually my 68 makes between 12 and 15 mpg
:cheers:
Olivier
Old May 8, 2002 | 08:56 AM
  #36
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
In 'normal' driving I get about 11.4. Or at least that's what I calculated the one day I ran out of gas. Whoops :D
Old May 8, 2002 | 09:33 AM
  #37
VettePower's Avatar
VettePower
Default Re: How much MPG do you get? (ddecart)
I get 10 gallons per month!! That is how much gas I used in a month just starting and running the car in the garage every few days while I am restoring it!! :lol:
To How much MPG do you get?
Old May 8, 2002 | 03:30 PM
  #38
redwingvette's Avatar
redwingvette
Default Re: How much MPG do you get? (GrandSportC3)
Since I changed from a 3.08 to a 3.55 gear the best I get is around 11mpg on a trip.
Old May 8, 2002 | 04:22 PM
  #39
chrisgable's Avatar
chrisgable
Im like Burners only 350 turbo instead of 4 speed. My car loves the higher rpm range. My odometer dont work so I have not checked mileage but I went this weekend from Dorr to Lansing drove around Lansing and drove back to Grand Rapids on 1 tank of gas. Thats not too bad at 80 - 85 with 3:73's
estimate about 220 mi total. I dont know you do the math. Im not sure how big of a tank it is 20 gal? about 11 mi to the gal if thats the case but at 4000 rpm I still dont think thats bad. :cool:
Old May 8, 2002 | 09:36 PM
  #40
American Boy
Default Re: How much MPG do you get? (chrisgable)
Today, I decide to pop the top of the Quadrajet to try some primary jet and rod. It was the first time so I checked everything. Fuel bowl height was set too low and to my suprise, the power piston lower stop was set too high. Well about 1/2" too high. So when cruising, the primary rods weren't closing the hole on the jets causing a rich condition for sure. I've set it as per Lars technique and well see how much improvement that'll do.
Now, the engine run even smoother than before and seem to like the richer jets rods that I put on it; 73,44 in replacement of the 71,43.
Stephan
