How much MPG do you get?
Old May 7, 2002 | 04:00 PM
American Boy's Avatar
American Boy
Default How much MPG do you get?
I am in the process of tuning my engine for MAX performance (L48) as I can get. Either for gas consuption or acceleration. The ignition is done; 34 degrees mecanical at 2500 RPM and 55 degrees total at the same RPM. The car runs great.
When I cruise in town with stop and go, I get around 12 MPG.
On the long trip I just did (a Corvette cruise), I got 17 MPG.
I have 3,07 rear end and a TH350 with a non-operational lock-up with a Quadrajet for carb.
I wonder if I could get better millage from playing with the carb; power piston spring, jets and rods.
Show me your numbers.
Stephan
Old May 7, 2002 | 04:08 PM
KorbenDallas's Avatar
KorbenDallas
Default Re: How much MPG do you get? (American Boy)
I get about 8mpg, but I've got a 4sp right now and no OD. I frequent the highway @ 3500+ rpm and I'm running rich.
I think stock for '81 C3s gets 12mpg.
Old May 7, 2002 | 04:11 PM
norvalwilhelm's Avatar
norvalwilhelm
With a 460 cubic inch engine , a 8-71 blower, 2 850 double pumper carbs, 4.11 gears and overdrive transmission I get 12 mpg anytime around town without fouling plugs ever.
Old May 7, 2002 | 04:12 PM
Chuck Harmon's Avatar
Chuck Harmon
I used to get that same mileage with my '79 L82 with 3.55 gears and Trubo 350. I would expect you to get a little better with the 3.07 gears. The only real way to know for sure on your setup is to use a chasis dyno with an A/F ratio measurement. Dial in your mixture at part throttle highway speeds, perhaps evenas high as 16:1; but, make sure your full throttle ratio drops to between 13-14 to 1 when you ask for it.
Chuck
Old May 7, 2002 | 04:15 PM
Fevre's Avatar
Fevre
0
Of course my speedo/odo aren't working. :)
I think 55 degrees total timing is a bit much, actual way to much. I believe your total timing should be betweeen 36 and 38 degrees. Check Lars' tuning paper for exact spec's.
Old May 7, 2002 | 04:18 PM
Fevre's Avatar
Fevre
Default Re: How much MPG do you get? (Fevre)
I retract that statement about total timing. :bb
Old May 7, 2002 | 04:20 PM
American Boy
Chuck
I'm going on a wheel dyno at the end of the month. I hope they have an A/F ratio thingy to check mine.
Fevre (I forgive you :D )
For others interested
The mecanical advance is only 34 degrees. When we speak of total advance, it include the mecanical and the vacuum. 55 degrees for the total was what I read somewhere on the forum and it's working great.
Stephan
[Modified by American Boy, 3:21 PM 5/7/2002]
Old May 7, 2002 | 04:24 PM
verskel's Avatar
verskel
I'm running a Holley 3310 Vac. Sec. on a 427 B.B. with 'points' ignition.
My gas mileage :
On the highway ---> 14mpg on a good day (3:08 rearend) :D
In town -----------> 7-10mpg depending on traffic. :lol:
W.O.T. ------------> 3 mpg :eek:
Playing with timing & carb will help your gas mileage - but it's a trade-off. More power usually means less gas mileage unless you start 'swapping' parts on your motor to make it run more 'efficient'.
My friend's '82 crossfire averages a whopping 22mpg on the hwy. !!! :cheers:
Old May 7, 2002 | 05:01 PM
Darkness's Avatar
Darkness
I get more like 15mpg with moderate driving in the city and 24 in highway, checked last year on trip to Seattle around 65mph.
At WOT I can see the gas neddle move
FroDaddy>>The 1981 R&T mag, had 16mpg on the L-81 4-speed i'll post a pic later today
norvalwilhelm>> 12 mpg's:confused: how come. I'm thinking more like 12 gallons per mile :lol:
Paul
Old May 7, 2002 | 05:04 PM
challenger818's Avatar
challenger818
For pete's sake.......your driving a Corvette. Your not suposed to care about gas milage. It's the journey that counts. On a more serious note, I can't figure what kind oF milage I get because:
1. Haven't gotten though a whole tank yet
2. Haven't driven it without mashing the gas at least once (usually more)
3. If I had to estimate, I would say I'm going to get around 12 MPG (including the foot to the floorboard driving) Man do I love this car!! :chevy
Old May 7, 2002 | 05:11 PM
Taijutsu's Avatar
Taijutsu
I have followed this subject before. A strong SB w/o OD can get 17-18 mpg depending. To get much more than that will require OD. This is not to say that very careful driving won't do better, but REAL WORLD " reasonable take off,cruising over limit" driving it's hard to beat the 17-18 and 22-24 w/OD. It all comes down to how hard do you put your foot into it! I want to join the 12 sec 20 mpg club. This will not happen w/o 5 speed trans.
Old May 7, 2002 | 05:15 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I'm getting about 15 MPG and that's cruising at 80 to 95 most of the time, with 3.73 gears and a 4 spd. It's interesting, everytime someone brings up the subject somebody else pipes up about "who cares about gas mileage". Mileage is just another performance parameter to measure. So the point is "is it in tune", not "I don't care". I always check my mileage but when it comes to performance decisions, more power is the only way to go.
Alwyn678's Avatar
Alwyn678
Default Re: How much MPG do you get? (Taijutsu)
before the mods I was getting around 19 on the highway and 13 around town..I expect to be around 13hwy and 9 around town with everything i have changed...but who cares it will be FAST :smash: :cheers:
Old May 7, 2002 | 05:23 PM
Fevre's Avatar
Fevre
Default Re: How much MPG do you get? (burners)
burners
you must be reving abut 4000+ rpm's all the time with that set up. :eek:
I get scared at about 3500 on the highway, can just see a rod shooting out the hood/oil pan
Old May 7, 2002 | 05:32 PM
Chuck Harmon
When I set up my 69 L46 lean, I was getting 22-24 mpg at a steady 70 mph cruise with 3.36 gears and 4 speed. The secondaries realy need to be rich to bring the mixture back down when you open them for power.
Chuck
Old May 7, 2002 | 06:10 PM
Ingar, Norway's Avatar
Ingar, Norway
Fixing the lockup will improve milage and make the trans run cooler.
With the TH350C I got 15mpg town, 17 freeway.
The new 700R4 is 18 town, 23 freeway (55mph).
This is with very careful driving of course.
The gas prices over here makes you try to increase milage, this is what I have done to my stock L48:
Removed all emission equipment. (egr, canister, pvc, air etc)
Adjusted the Qjet piston to the bottom position (as per Lars' instructions).
Removed AC compressor (no need for it here..)
Electric fan.
K&N filter.
Dynomax headers with 2 1/2 true dual freeflow exhaust, no cats.
Fixed all vacuum leaks.
Next is TPI...
Old May 7, 2002 | 06:15 PM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: How much MPG do you get? (Ingar, Norway)
I get about 200 miles on a tank if Im lucky.I ahve two 600 hollys.th350 trans and 4.10 r/p.
To How much MPG do you get?
Old May 7, 2002 | 06:23 PM
corvettemaster's Avatar
corvettemaster
In my 81, with 3.07 gears, TH350C tranny (O.D. doesn't work), and a brand new, non-computer controlled Q-Jet, I get 12 mpg on interstate running about 70-75 MPH. I get 10 mpg on the highway runnin 50-55 MPH, and 6 mpg in the city. I usually get about 160 miles on a full 23 gallon tank. :p:
Old May 7, 2002 | 06:29 PM
Pete79L82's Avatar
Pete79L82
Default Re: How much MPG do you get? (challenger818)
What has my sake got to do with anything? I lost it awhile ago and I am still looking for it. :lol: :yesnod: :lol:
I get 16 on the highway and absolutely terrible around town. But then again I like to hear the sound of the sidepipes echo off the buildings around town, That might have something to do with it.
[Modified by Pete79L82, 4:31 PM 5/7/2002]
Old May 7, 2002 | 06:32 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: How much MPG do you get? (Pete79L82)
somewhere around 8-10 depending on how im driving
