LS-6 intake
Old Nov 29, 2011 | 06:04 PM
73 Rat Power's Avatar
73 Rat Power
Default LS-6 intake
Will an LS-6 intake fit under my stock 73 hood? Which performance intake would fit? Did they not punch out a few 70-71 LS-6 vettes with the stock big block hoods? The clearance on the 73 should be greater than the 68-72 BB hoods?
Old Nov 30, 2011 | 05:13 PM
Alan 71's Avatar
Alan 71
Hi 73 RP,
In looking at the pictures of the LS-5 and LS-6 manifolds, except for the fact that the LS-6 was alumnium, they appear to be the same height judging by the distance from the bottom of the air cleaner base to the valve covers.
So yes?
Regards,
Alan
Old Nov 30, 2011 | 05:54 PM
Ganey's Avatar
Ganey
The LS-6 intake is low. Many use the Torker II.
Yes, the 73-79 med. rise hood has more clearance.
The old Holley Street Dominator intake is another possibility.
Old Nov 30, 2011 | 06:12 PM
73 Rat Power
How much more would the motor breathe with another manifold? I'm also running full length Headmans with a K&N. Should I toss the Q-jet for a Holly?
Thanks, John
Old Nov 30, 2011 | 06:51 PM
roger3's Avatar
roger3
It did not fit under my stock 76 hood.
Roger
Old Dec 4, 2011 | 03:13 AM
Mr. Beam's Avatar
Mr. Beam
Yes, it even fits with a margin if you use a drop base.
/ Mr. Beam
Old Dec 4, 2011 | 12:18 PM
Solid LT1's Avatar
Solid LT1
The LS-6 intake is not a great power producer. Why Chevy put it onto the 70 Chevelle and then added a 2" spacer ring to seal the cowl industion aircleaner I will never understand when they had the 425HP 427 intake in inventory. I do understand that 427 intake was never going to fit under a Vette or Camaro hood but the Chevelle had tons of room.
Old Dec 4, 2011 | 01:27 PM
joewill's Avatar
joewill
the LS6 intake is a big square port manifiold, make sure it matches up to your heads, you may have oval port heads, most BB corvettes had oval port heads. you need to match up your heads to your manifold, or your manifold will continue to have the reputation of 'not a great power producer'.
Old Dec 8, 2011 | 05:39 PM
RickyBerg's Avatar
RickyBerg
Im not 100% sure about the 73-hood but its a bit higher than the earlier smallblock hoods isnt it?
I run a LS6 intake on my 454 under the stock 72 bigblock hood with OK clearence.
The LS6 are the same height as the iron LS5 intake.
The LS6 intake even works with a 1/2 inch spacer if you use the "L88" base for the aircleaner witch make the aircleaner drop even more.
HOWEVER.. There may be an issue with the carbs choketower getting to close to the filter lid when using the "L88" filter base, therefor i milled down the choketower on my Holley.
Works great for me.
//Ricky.
To LS-6 intake
