Build thread: LS into 1975 Convertible
I finished the heat shielding in the cabin last night, and now I'm ready to run the wiring harness and find a home for the computer and the relays. Going to order a trans crossmember from Custom Image to use with the T56.
Slowly but surely...
I also modified the F-body radiator and E-fans that I got with my engine and trans to fit the stock radiator support. I'm pretty pleased with it, except for the fact that my radiator support is kind of in rough shape to begin with. The radiator hoses line up with the motor like a thing of beauty, and the line to connect to the steam tubes is already in place. I've just got to install the temp sending unit in the upper radiator hose (got an autometer piece that goes in the hose with a fitting for the stock sender), and I'll be finished there.
I'm getting close to being ready to fire. I ordered a set of F-body headers to use as a temporary exhaust system until I can get these sidemount headers worked out. I also need to get my power steering lines fabbed up. I ordered some parts for my air intake setup as well. Still need to bleed clutch, and download the tune off the stock PCM with HPtuners so I can modify the tune to delete VATS, AIR, EGR, rear O2s, etc. Then put the steering column back in, hook up the battery, and turn the key and hope for noise.
Will update with pics when I get back in town this weekend.
Can you detail post the fit of the F body headers? Some say they will not fit, and
some say they will, with a little massaging. I would love to see what you come up
with, and with photo's
Riggs
the headers be closer to the floor board, instead of hanging so low.
I would guess that the headers would and will vary in shape and fitments
depending on each manufacture.
Looking forward to your updates.
Riggs
Here's a shot of the F-body radiator and electric fans in place with my slightly modified stock radiator support. Everything lines up really, really well.
Another one, from the top.
I need to loosen the clamp on the lower hose, and rotate it a bit to get the hose to angle and line up a bit better, but I think I'm going to be able to use it as is. I also wanted to find a coupler to install in the upper hose to mount the stock temp sender in, but so far no luck...
Here's a shot of the space I'm looking at for the driver's side header.
Whether the F-body headers will fit easily or not is anybody's guess at this point. I'm going to be optimistic that I can make it fit.
Here's a shot of the Pacesetter F-body headers...
Let's see what happens.
I am really interested in those headers, What size primary tubes are those?
Comparing photo's with my modified headers, it looks like the headers will also clear the steering stem for the rack,
But I am questioning the passenger side, I wonder if the last down tube will hit the firewall?
Keep us posted.
Riggs
Quil: Try 'jagsthatrun' for a coupling. They have a whole bunch of couplings and there ought to be something they have that works. they were real quick in getting some couplings to me by mail. Here's a link to start with
http://www.jagsthatrun.com/Pages/Par...g_LSI-tee.html
http://www.summitracing.com/search/P...pter-Fittings/
Riggs
I got a ton done today. Waiting for my camera battery to charge so I can post pics. The F-body headers are in. The collectors on both sides barely hit the floorboard and have to be flattened a touch, but otherwise they fit like a freaking glove.
Should have pics of todays progress up within the next half hour or so.
