Build thread: LS into 1975 Convertible
This is the spec on the cam, nothing to radical, but it sure works well with the heads,
Hydraulic Roller Tappet, Duration @ .050 in. 238/242, Lift .595/.595
The motor Ran real strong with this top end kit, and the tune was not dialed in, I was
working on that as I discovered the noise of a rod knocking. I suspect that the motor
ran with out oil for at least a few minutes in the SS Trail Blazer it came out of, maybe
even upside down, you never know what you are truly getting when you are buying
a motor from a salvage yard. Next time I will take better precautions.
Any how, I hope your start up goes really well, so you can get this LS swap finished
and start enjoying the car on these beautiful days we are having now.
On a side note,
If you still have the car up on stands, or the next time you do, could you snap a
couple more photos of the F-body headers, I would like to see some more detail
as to how they run with the fire wall and down to the floor board, from the photo's
you have posted, I can't really see the routing of the rear primary and how it travels
along the fire wall, I hope I would not have to lose the heat shield, I do intend to
cut the 3'' collector and re-angle it for better positioning away from the floor board.
They may even fit better than I am thinking, my trans crossmember mount is a
little lower than I have seen others, so maybe this will give me a better angle for the
F-body headers to fit with no modifications.
Riggs
So the engine fires right up immediately...good oil pressure, alternator is showing a charge, everything is running great. Except for a horrendous screeching sound coming from the belt drive system somewhere. Sounded like it was around the power steering pump, so I pray its not bad. Full of fluid. I am running the wrong belt tensioner, so I'll need to replace that to start, and then troubleshoot from there.
The engine warms up fully, and....no fans. I start testing the terminals on the relay. Definitely getting power from the battery to the relays, and the terminal receiving the input from the computer is also showing a signal. But no signal on the terminal going from the relay to the fan itself. Not sure what is going on there. They are 40 amp relays, and everything is wired correctly, I triple checked...
So overall, I'm happy. I'm just glad it runs so smoothly and had good oil pressure. I'll get the rest sorted somehow.
What are you looking at for the temperature of the motor? The Gauge or HP Tuner live data? My gauge was off by a 30/40 degrees, I believe it's because the sender is mounted in the passenger side head with a reducer that doesn't allow the sender to protrude out into the coolant, So I think mine is probably picking up the temp of the cylinder head, more so than the coolant temp. Any how, my fans came on when the HP Tuner screen showed the temp being at the on setting, (180).
Might this be the same thing you're dealing with?
Riggs
I'm looking at water temp on HPTuners, off the stock LS1 sending unit in the driver's side head.
(By the way, "Corvette Joe", who I reference in the vid, is a buddy of mine back in Alaska who has put LS motors in midyears for a long time now. He inspired me to tackle the swap. Oh, and don't mind Safari Goofy...he sits in on all my projects)
Have you jumperd the relay coils to see if they would come on, you should hear them click when you
apply power. If the relay coils are working, maybe the fans are the problem, have you applied power
straight to the fans to see if they come on? Just throwing out some ideals here. Hope you find it soon
so you can road test the car.
Riggs
I've got power to the relays, and I've grounded the relay, so I should be seeing something coming off terminal 87 that goes to the fans themselves, but there's nothing there. These relays are brand new, so I'll be surprised if they are bad, but stranger things have happened I guess.
The car is a long way from a test drive. There is no interior in the car, and I still need to get the driveshaft measured and shortened. But I'm close. Just glad it runs and fluids aren't spewing everywhere.
Now I just need to know for sure what size fuse to use on the power wire to the relay. 30amp is working now, but I have no idea if it might blow as well.
I'm still troubleshooting an issue with my water temp gauge. I've tested the gauge itself, and it works as it should. The sender is the same one that came out of the car, and it was working fine when pulled. I have the sender installed in a coupler in the upper radiator hose, and I can't remember whether or not I erroniously wrapped the sender in tephlon tape before I installed it or not. So I'm still figuring that out...
I have been putting the interior back in for the last week. Yes, you read that right. I swear on all that is holy, the interior reinstallation has been worse than the LS swap. This thing fought me every inch of the way. I had portions of the dash in and out probably 5 or 6 times. I have it all together now, but I'm still not very happy with how it turned out. I'll try again when I have to pull the driver's side lower dash out to do something with the speedometer.
My T56 crossmember finally arrived today. I only ordered the thing 2 1/2 months ago. So now I can get that bolted up and see where I am with the driveshaft. Once a driveshaft is in, it's drive time.
I've also got to do something about the ride height now. Since pulling the spare tire carrier and spare and doing the engine swap, this thing looks like a damned 4x4. I bought longer bolts and new bushings to lower the rear, and I guess I'll cut the springs in the front to get it down some.
I'll try to get pics up soon.
The Corvette interior is a love hate relationship, when put back together correctly it looks nice, but while putting it back together, it can be a challenge to reinstall with out breaking something. It gets easier the more times you have to take it apart and reassemble, but it still is never fun.
Hey do you have some pictures of the cross member, I would love to see some of it before and after installing it. Does it give you better cut outs in the cross member for running the exhaust past it?
Good to hear you're still making progress.
Riggs
How far off were your temp readings? Are you using the 3 wire setup with the stock LS1 temp sender?
Riggs
