Build thread: LS into 1975 Convertible
Old Jul 4, 2012 | 10:47 AM
  #141
Garys 68's Avatar
Garys 68
Yep, run a wire from the fitting to the block.
Originally Posted by Quil
No it is not. And I'm going to assume since you asked that it needs to be...
Old Jul 4, 2012 | 12:07 PM
  #142
Quil's Avatar
Quil
OK will do. Thanks for the heads-up. I thought the sensor would be grounded since it was in the coupler, but didn't really think about the fact that the coupler is in a rubber hose and isn't grounded itself.
Old Jul 29, 2012 | 07:53 PM
  #143
Quil's Avatar
Quil
So long time, no update. I'm back with a ton of pics I took today of what is a 90% completed swap. Today was my customary day of garage clean-up and car clean-up after what has been a long and challenging journey. Onto the pics.
Riggs had asked for pics of the crossmember I was using for the T56, so here's a few. Sorry for the fuzzy pic on the first one. I had issues with the trans mount holes lining up with the slots on the crossmember slots, even as long as they were. I think my engine is sitting just about as far forward as you can get it without hitting the front crossmember. For reference, I only had to have 2" of driveshaft cut out...from 29.5 to 27.5...
I ended up biting the bullet and cutting up my stock shifter console plate. I hated to do it, but it was pretty much my only option. As you can see in the pic, I combined the holes on the right and left into one big hole (this was an auto console). More pics of finished product installed later...
For my MIL light, I decided against drilling a hole in my lower dash and opted to use the existing hole where the vent open/close **** came through. I never use those ***** anyways, and I thought this worked well.
Here is my finished console plate. Believe it or not, I made the shifter boot myself out of a piece of black vinyl I got at an arts and crafts store. Not the greatest, but it works. I am also using a WS6store short stick for the shifter...I thought the height was perfect.
So here's the finished product in the engine bay. I'm relatively pleased with how it came up. Still going to do a little more cleanup on the wiring harness and add some loom here and there, as well as paint touch-up.
Fuel rail covers are painted semi-gloss black. I tried going with gloss black and a clear coat, and it didn't come out well...
So that's about it for now. I'm still deciding about the exhaust...I'm trying to talk myself into spending a couple grand on a custom set of sidemount headers and sidepipes to finish it off. Otherwise, I'll go to an exhaust shop and get them to fab up something temporary underneath...just a couple mufflers and then dumped before the axle.
Here's some after pics of today's car clean-up! Car is now lowered on 8" bolts in the back, and new coils with one spring cut in the front. There's about 1" of rake from back to front, with ride height in front being 26.5". Enjoy!
Quillen Motorsports Engineering (my brother's shop) in the house!
Thanks for following, guys. And thanks so much to all the LS-swappers who came before me and helped me out with tech support and advice. Couldn't have done it without this forum and you guys. I'll update when the exhaust is in, and as modifications come along. Cam, heads, intake, throttle body all to come, and eventually...Maggie supercharger!
Old Jul 29, 2012 | 08:35 PM
  #144
'75's Avatar
'75
Beautiful car, good job!
Old Jul 29, 2012 | 08:52 PM
  #145
riggs 74's Avatar
riggs 74
Wow, it turned out beautiful, both the swap and the look of the car.
A local friend on mine just finished a 74 vert restoration same color as yours, I was trying to get him to drop in an LS but he was building it to sell off to fund his 74 he's looking to build next, maybe I can convince his to go with the LS in that car since he is going nuts over my LS setup.
looking forward to seeing some video when you have it a 100%
Riggs
Old Aug 12, 2012 | 12:33 AM
  #146
Blain's Avatar
Blain
Default Trans cross member
Where did the trans cross member come from? ( I appologize if you mentioned it earlier)
Thanks, Blain
Old Aug 12, 2012 | 07:40 AM
  #147
Garys 68's Avatar
Garys 68
Did you get all the gauges working?
Old Aug 12, 2012 | 08:09 AM
  #148
Quil's Avatar
Quil
Brian, the crossmember is from Custom Image Corvettes.
Gary, all gauges except speedo work. Tach is way off. Going to replace speedo and tach with an Autometer setup.
Old Aug 12, 2012 | 11:13 AM
  #149
brent319's Avatar
brent319
C3 of Year Winner (appearance mods) 2019
The car turned out great.
Old Aug 13, 2012 | 07:43 PM
  #150
68roadster's Avatar
68roadster
I like. Nice engine bay!
Old Oct 28, 2012 | 10:41 AM
  #151
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
looking swap.
Old Oct 29, 2012 | 09:46 AM
  #152
Dantana's Avatar
Dantana
That really looks impressive. I can't wait to try one myself. One project at a time though, right now I am finishing my basement.
One thing you might try, something that I get a lot of compliments on, is powder coating your master cylinder. I did the MC in black and the top in red to match the theme of my C3. I think it looks a little more unique than just a chrome one and I had it done locally for under $100. Just a thought.
Great looking build!
-DT
Old Oct 30, 2012 | 06:06 PM
  #153
Quil's Avatar
Quil
-DT
Thanks for the suggestion, that's a really good idea. Eventually I'm going to change the color of the car, but I definitely wouldn't mind trying something like that, because the MC is kind of ugly right now. I'm also going to buy a set of chrome or black chrome caps for the oil fill, radiator cap, etc.
Old Dec 29, 2012 | 11:26 PM
  #154
DEEPSEA70's Avatar
DEEPSEA70
Q,
I am in the same boat with my shifter plate. How did you secure the boot you made to the plate. Did you screw it in from under, or side, glue it in place? I have an LS3 Dry Sump and TKO 500 with shifter in the middle.
Thanks.
Old Dec 29, 2012 | 11:34 PM
  #155
Quil's Avatar
Quil
Originally Posted by DEEPSEA70
Q,
Thanks.
It's held in place with some binder clips right now...I wanted to see how well the boot looked before I made it permanent. I need to take it back off and try some two-part epoxy on it or something. Not sure how else I could hold it in place...the plate is thin so I don't think I'd be able to use screws.
The boot actually settled in and looks 10 times better now than in that pic...lol.
Old Jan 12, 2013 | 02:59 AM
  #156
DEEPSEA70's Avatar
DEEPSEA70
Default temp sensor for my LS 3
Riggs,
I need to set up my temp sensor. The original gauge dark green wire will go to the passenger side head with S&P adapter and original temp sensor. Does the LS tempe sensor interact with the ecm and plug into the driver side head temp sensor. So I will be using both sensors? How would I get the reading, or do I need to get the readings from the LS sensor on the drivers side, or does the ecm handle it, or do I program that out and just go off the original gauge? Thanks for any ideas. Take care.
Pic of LS sensor, do I still use it since I'm running the 70 gauge.
Thanks.
Originally Posted by riggs 74
The temps were off by about 50, I'm referring to the single wire sensor for the gauge, the one for the ECU seams to be fine. With the car up to operating temps, the one for the ECU reads around 190, while the one for the gauge reads as high as 240/250, it had me really worried until I was able to hook up HP tuners to it and have a look at what the ECU was seeing.
Riggs
Old Jan 12, 2013 | 11:43 AM
  #157
MrJlr's Avatar
MrJlr
A work of art....you should be proud!!!!!!!
To Build thread: LS into 1975 Convertible
Old Jan 12, 2013 | 11:58 AM
  #158
riggs 74's Avatar
riggs 74
Yes you still need the driver side sensor if you're running fuel injection so the Ecu can monitor the temp for the fuel/ air mixture circuits.
My gauge sensor was off because of a faulty sensor, but has since been replaced.
Riggs
Old Jan 12, 2013 | 12:57 PM
  #159
Quil's Avatar
Quil
Update on my car/build...
I just finished installing parking brake components onto the car (previous owner removed the assemblies completely), and everything works, which I am quite proud of considering the horror stories I've read about parking brakes on C3s. Now I need to do some other small things like adjust the side windows to seal better with the convertible top, paint my rally wheels (back to silver...PO had painted them body color), and some other minor jobs.
I did finally bite the bullet and order a custom set of 304 stainless sidemount headers and sidepipes. Hoping to see them on my doorstep here in a month or so. They weren't cheap, but they are high quality craftmanship and sidepipes is really what I want on the car, so I had a mini-firesale of car parts to lessen the financial blow. Here's a couple pics of the exhaust from the manufacturer's website...
Really looking forward to getting this exhaust on.
Old Jan 12, 2013 | 02:15 PM
  #160
DEEPSEA70's Avatar
DEEPSEA70
Wow, those are beautiful headers.
I took 2" out of my parking brake front cable and had it re-crimpped, works very well.
Riggs, thanks for the heads up. I will be using the EFI, and it makes perfect sense now.
