C3 Corvette heating up?
So I have a '79 Corvette, and I've been reading on the forums about how you guys fixed your heating problems. My car is generally cool when idling (I live in Florida so that's good) except when I take it out, and I get stuck in traffic, which is ALL the time, it heats up to 220.
From what I've read, I understand that 220 is nothing to be alarmed about but is there anything I can do to cool it down?
So far it has a new aluminum radiator and a new thermostat that's supposed to open up at 160, yet it still gets to 220 during normal use.
Make sure your timing and carb mix is right, as well.
IMHO, a 160 degree thermostat is not hot enough. Compromise with a 180.
Scott
I had forgotten a few things though, firstly, let me mention I am no mechanic. I am 18 years old, (I'm sure you all just shuttered at the thought of someone like me owning one of these.
) and I've never been a very big car guy. Anywho, It's my first car and I am its second owner.I was told it hadn't been run since 2001 which is why the interior and so forth was in such bad shape but the worst part (mechanically) is that the engine is FULL of... I don't even know what it's called. I mean, it looks as if someone took a bucket of paint chips and dumped it in, so I'm assuming that may be one of the reasons as to why it's so messed up.
When I first got it, it had no thermostat and worked slightly cooler because of it but when it became heated it BOILED which obviously wasn't going to work. The first thermostat we bought was a 180 one, and it locked up in about 2 weeks with no major use. As I previously mentioned it currently has a 160 and so far so good... or rather "okay".
I'll be sure to let you all know how this turns out and again, thanks.
I was 19 when I bought my first car 1981 CORVETTE! (That was last year
Dual electric fans will surely help or you could look into Evans coolant. It's waterless, has very high boiling point (over 300 degrees) and will help with detonation issues.
Id look into the fan as other said and do a pressure test (cooling system) and leakdown test on your engine.
If it all proves sound then get some real coolant in there
Being as youre in Fla where its hot a lot dont see any harm with a 160 thats all I run here in Ca.
By the way, everything, except the aforementioned radiator as well as the exhausts, are the original parts from when it came off the assembly line in '79.
OP stick that sucker in park get your revs up hold it there then carefully watch your hoses, mainly the lower where it comes out of the water pump.
Scott
OP needs to drain some water and put a gallon of anti-freeze {100% antifreeze....not the "pre-mixed" stuff} in with the water to get near a 50/50 mix. That will raise the boiling point of the coolant to around 240F so that the coolant will stay in a liquid state, anyway.
Then, install a 180F stat and try it out.
So what exactly is up with this "Paint Chip" stuff? And you say this is in the engine?
Also, to the post after this one, the radiator is NOT 32 years old, it's brand new. It's one of the few things that were replaced.
Scott
