[QUOTE=682XLR8;1579457483]I have my wires routed behind the heat shields on the block, under the headers, so 90's are about my only choice
Had memory fade on that one! I forgot your engine still had the heat shields, 90 degree boots are what you need. I used the 135's because of the Hookers.
Box from Summit came in today.....opened it, took out the new plugs I had ordered, and sent it back to Summit....already ordered the Accel wires ($150) & they should be here Thursday, looks like I know what I'll be doing this weekend!
Came back from a short cruise around the neighborhood, and was checking out the engine when I turned the lights out checking for arcing...and sure enough the wires are arcing right at the plug....all eight of them Let the engine cool a bit, removed the boots and applied dielectric grease to each boot....same result There's a weak link in the ignition system somewhere, but before I go buying parts I want the Forums opinion on this
The System:
MSD tach drive distributor
6A box
8mm MSD Heli-core wires
AC 41-629 plugs gapped at .035
Blaster 2 coil
Everything is about eight years old with maybe 6-7000 miles on them except the plugs, cap, rotor which are ~ 3 years
Any suggestions?
I havent read thru each and every post made here as its into many pages now...but....what i found is that the MSD6 Box really puts out some spark and if the ignition wires/boots arent up to the task, the spark will jump to ground easily. I had the same problem as you for the longest time and tried all the high end Ignition Wires such as Taylors extra thick wires, ceramic boot and wire set, etc... and nothing worked until i put on MSD's low resistance , 8.5 mm , Super Conductor wire set -- they are the only wires that will handle the juice flowing thru the wires and if im lucky, i can get about 3-4,000 miles out of them . I often check for shorting and grounding of the wires as well as the Distributor Cap and MSD box wires when pitch dark as thats a good time to notice anything amiss . I too have a MSD6AL box with correct plugs gapped at .045 " but im going to return to .035" for less resistance. I also have those high temp Boot Covers over the boots which are supposed to handle 1200 f. of heat ... a must when youre running Headers.
and nothing worked until i put on MSD's low resistance , 8.5 mm , Super Conductor wire set -- they are the only wires that will handle the juice flowing thru the wires and if im lucky, i can get about 3-4,000 miles out of them.
Sounds like what I have now
So far I have not seen any activity at the distributor, nor have I seen a spark actually jumping to ground i.e. the block, maybe arcing is the wrong word to use, but what I am seeing is what looks like static fizzling around each boot right at the porcelin. This activity is not shooting sparks out that I can see, but looks to be restricted to the boot/porcelin area, and it is very clearly visible around all eight boots when the lights are turned off
Id try switching to basic Champion plugs for your block . I once tried the high-energy iridium plugs and they didnt work out well .
Do you really need an MSD box that puts out 50 million volts? Would going to a regular coil help?
the MSD box does make my car run better for cold morning starts.... but I do not have a choke either, Might Demon 750's dont have them.... so this helps me..... also, when up around 6500-7000RMP I think it helps keep the spark from blowing out.... but for a stock car.... no, you don't...
Probably not, but I already have it installed and see no reason at this point to get rid of it
Back when I was gathering parts for the engine build(before my Forum days), the only tach drive distributor I could find at that time was the MSD.....the HEI's on the market at that time were pricy, so I thought the MSD was a great deal. When it came to install, I read the instructions a little more thoroughly, and that's when I saw that I needed the 6L box to make this work....so much for saving a few bucks
Originally Posted by DC3
I went through three sets of plug wires and even more sets of boots before I bought these Accel ceramics. So far so good.
DC
That's good to hear the Accel's are holding up how long have you had them for?
Have you tried putting dialectric grease inside each boot and around the plug where its fizzling , just to see if it helps ?
Have you contacted the Spark Plug Manufacturer or the Ignition Wire Manufacturer to see if they can shed some light on this occurence ? When you get to the bottom of it, would you please make a post here just in case it happens to me or another in the future (?) . Im very curious at this point.... Thanks.
My next step is to replace the plugs and wires with the Accels I provided the link to.....as soon as I get the time to get out in the garage and do it I have the headers and heat shields off the car now, just need to assemble the plug wires and put it all back together
I'll definitely be posting the results when I get it running
You've got the headers off AGAIN?????? What's wrong, are you a glutton for punishment?
I've got the ps pump out now, it was leaking and squealing when I turned the wheel, so there you go. I guess we all like taking bits off and putting them on again.
