Arcing at the plug boots
You've got the headers off AGAIN?????? What's wrong, are you a glutton for punishment?
I've got the ps pump out now, it was leaking and squealing when I turned the wheel, so there you go. I guess we all like taking bits off and putting them on again.
Regards from Down Under.
aussiejohn
Plug wires are in, I was re-installing the headers when I had to stop working for the evening.....I'll finish up tomorrow and post up with a full report
If my longer term experience is as good as others who've installed them, I'll be happy.
DC
I did notice that these Accel boots don't fit as tightly as the MSD ones did...of course I didn't find this out till the wires were cut and installed.....the part of the wire that snaps onto the end of the plug fits fine, and the car runs great, just this one little issue
Everyone has been very helpful so far, any more suggestions?
Really thought the wires would be the answer.
Champions were suggested earlier in the thread any other recommendations?
After checking online and talking to some of the electronic techs here at work, I think what I'm getting is the 'corona' effect, that is, the air around the plug being ionized. The online descriptions say a 'glow' where as I'm seeing more of a 'flickering' around the plug, but the engine does not have any miss to it and runs fine
Anyone have any more suggestions?
The voltage is supplied by the dist to the plug, the plug has a ground strap that is grounded through the threads of the plug to the heads.
Try using a set of jumper cables and ground the head to the battery and see if this resolves the issue, if so look for a bad ground to the block, maybe even try a ground wire to each head.
I know its out there but its easy to try.
Neal
....as I have to work during the day, I don't have the time to sit on hold for very long, so I sent requests for support on both websites....will report if and when I hear something The voltage is supplied by the dist to the plug, the plug has a ground strap that is grounded through the threads of the plug to the heads.
Neal
Good idea though, it was worth a shot
I think you oughta change your medication! The CORONA effect?????? What the hell.....???? There's nothing Toyota about your car, or wasn't last time I saw it. What have you changed?
aussiejohn
You're in the performance car business. Don't be spreading 1950s myths.
MSD's response:
Dear Sir:
Is the arcing occurring such as a lightening bolt would ‘snap’ or is it more like a glow and sound like sizzling bacon?
If glowing that is a common problem and is know as a corona. There is no damage being done it is just an anomaly when the right atmospheric conditions are present and is sometimes referred to as “Saint Elmo’s Fire”. http://en.wikipedia.org/wiki/St._Elmo's_fire
If snapping like a lightening bolt then to might have a carbon arcing problem and the energy is looking for the easiest path to ground.
You might also make sure that the engine is grounded directly to the block using a double aught cable (.00) and then from that point on the block using a 10 gauge or thicker wire to each cylinder head.
This assures that the best possible ground exists between the battery and the engine. DO NOT rely on frame or chassis grounds. (see attachment)
Thanks,
MSD Tech
The attactment the tech is referring to shows a pic of a big block and where to run ground straps to each head, just as chevymans 77 suggested
Neal
Here's Accels response:
Why you are experiencing this type of effect is related to one thing. The wires for the spark plug boot are close to metal so this is why you are seeing somewhat of a light show. What is happening is that spark is jumping from the wire to the engine block. Simply pull the wires back away from the block. Thank you
I'm not sure he understood the question correctly, as the spark is not jumping anywhere
