L98 heads
Old Dec 14, 2011 | 06:19 PM
bmprhmpr's Avatar
bmprhmpr
Default L98 heads
Hi, Ive got a 78 vette (doin a frame off) with the 190 hp 350 (L42?) Need more hp to say the least. Ive got a set of L98 # 10088113 aluminium heads, 58cc,1.94/1.5 valves Will these heads help with maybe a Edelbrock intake and carb and a mild cam? Also will stock pistons work with this type of set up?
Old Dec 15, 2011 | 07:00 AM
Marlin's Avatar
Marlin
I think the older motors had larger chambers so you will get a good size bump on compression.
The L98 heads are not top of the line but should flow better than what you have if i remember. Get the head number off the heads you have now, never know they could have been changed in their life. Compare the the flow and combustion chamber.
Also check the head numbers on the L98s you have. The early ones had some cracking issues. Been a while since I was a tech but L98 was the big thing when I was and I remember that much.
If they are a good set then I would run them. But yea a little bit bigger cam, not to big, and a good intake shoudl do whonders.
Old Dec 15, 2011 | 03:21 PM
GS977's Avatar
GS977
i used 89 vette 113s on my 350. i got the heads for free from a good friend so i just paid for a new valve job and a slight mill to get them staight. i did a little clean up porting myself. i put in a small comp cam and i'm surprised the way they perform. my comp is 11.1 :1 with a .038 quench and it runs perfect on pump 93 gas. i would use them again on a mild street motor on a budget. here they are before and after.
Old Dec 15, 2011 | 03:47 PM
scottyp99's Avatar
scottyp99
I think it would help the OP alot if he new what cam you were running with that combo, so he could compare it against his choice. With 11.1:1 SCR, you must be running a pretty good amount of duration to run well on 93 octane gas, and the OP talks about using a "mild" cam. I would be interested myself, maybe the tight quench is allowing you to run a high DCR. Thanks,
Scott
Old Dec 15, 2011 | 03:56 PM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
Old Dec 15, 2011 | 07:04 PM
wombvette's Avatar
wombvette
Those heads have a different center bolt pattern , angle, than older manifolds. Make sure the intake will fit or can be modified.
Old Dec 15, 2011 | 07:49 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
gonna go on a limb here and say the original came with 882 cast iron heads. the L-98 aluminum heads are a decent stock casting. and if i'm not mistaken, you will nneed to go with a late model intake because those heads have a slighly different bolt pattern on the intake
Old Dec 15, 2011 | 07:50 PM
GS977's Avatar
GS977
i'm running the comp cams thumper
.479/.465 227/241 @.050 107 sep these specs are with 1.5 rockers. i'm running 1.6 so the lift is just over .500 if i remember right.
when i did the dynamic comp calc when i was building the motor it was right at 9.0:1 thats supposed to be too high for pump but i've had no problems.it could be the quench. my flat top pistons are .023 down in the hole and i used a .015 head gasket. and my pistons have a single trough. which i've read is the best for flame travel. my total timing max is 36* from @ 2800 on up.
i thought gm still used the l98 113 heads on the zz350 crate motors.
Old Dec 15, 2011 | 08:04 PM
GS977's Avatar
GS977
i used a edelbrock perf rpm intake i got used. it was on a 78 camaro with the original motor. the intake bolts right up to these heads with no problem. you can see the perf rpm in the pics.
Old Dec 15, 2011 | 08:06 PM
scottyp99's Avatar
scottyp99
Ahh, camshaft size is so subjective, ya know what I mean? I think of a cam like that as a pretty big cam! I guess it's all relative to what you get used to, huh?
bmprhmpr, what do you consider a "mild" cam?
Scott
Old Dec 17, 2011 | 05:04 PM
bmprhmpr's Avatar
bmprhmpr
Yall are way beyond me with cam tech. (ive only built engines with stock parts) The stock heads have a #462624 casting no.,76cc, not sure of valve size,Ive read they used 3 different valve sizes with these heads. The bottom end Ill rebuild to stock, use the L98 heads and performer intake and carb with headers. So Im lookin for sugjestions on a cam. Im lookin for 300 hp. nothin serious. Thanks for all the imput.
Old Dec 17, 2011 | 05:23 PM
bmprhmpr's Avatar
bmprhmpr
A little lope at idle would be a good thing
Old Dec 17, 2011 | 10:40 PM
GS977's Avatar
GS977
i have a isky 270 mega cam and lifters i pulled out of one of my previous 350 motors. 75.00 if you want it. i was running it with my l98 heads when they were stock, no porting and it pulled hard for such a small cam. and has a little lope to it.
the specs are .465/ .465/ 222/ 222@.050 108lsa
Old Dec 18, 2011 | 11:46 AM
bmprhmpr's Avatar
bmprhmpr
GS977 is the cam a roller or flat tappet hydraulic and how many miles do you think are on it?
Old Dec 18, 2011 | 12:15 PM
rcread's Avatar
rcread
I put L98 heads on my '71. They were a nice performance improvement over stock, with good low end torque. Though you'll need center bolt valve covers, a stock type of intake manifold will bolt up just fine. The heads have no heat crossover, which may affect your choke set up.
Old Dec 18, 2011 | 06:13 PM
GS977's Avatar
GS977
i bought the cam used from a friend so i don't know the milage on it. i bought the lifters new and put @ 2000 miles on the cam and lifters.
it's a flat tappet hyd.
i went with a bigger cam, thus the reason i don't need it anymore.
Old May 19, 2012 | 02:09 PM
kerjm72's Avatar
kerjm72
1st Gear
Default help
hey, was woundering if any of you new were i could get the inner spring if thats what you call it. i was upgrading my valve covers and looked inside and found a piece of a spring (not the heavy rounded spring) but the flat one inside of the heavy rounded valve spring. ive been looking all ove the place and havent even seen them. every time i type valve spring for 10088113 it gjust shows the outside spring. help.
thanks
kerry
Old May 19, 2012 | 03:50 PM
cv67's Avatar
cv67
St. Jude Donor '05
imo the Isky 270 will run circles around the thumper from a leave and be much easier to drive with that head/intake. Great all around street cam.
Some of the old tech flat out works.
To L98 heads
