69 QJet
Old Dec 18, 2011 | 08:16 PM
MosportGreen66's Avatar
MosportGreen66
Default 69 QJet
Hi Guys,
Just installed an original Qjet on a 69 Corvette. Can anyone provide insights how to tune it.
Thanks,
Dave
Old Dec 18, 2011 | 08:36 PM
Limey1955's Avatar
Limey1955
Below is a response I got from 7T1Vette on the subject. I had my carb rebuilt professionally, just got the car back yesterday with a big improvement in performance and driveability.
Buy the Chevrolet Chassis Service Manual for 1969 and adjust the carb and choke per the procedures in that manual.
If the carb is original to the car, you just need a rebuild kit (NAPA, Echlin kit for your carb part number...found stamped into the left/rear corner post of the carb). Also buy a brass float for the carb P/N and dunk it in a mug of water to check for any air bubbles (possible leaks).
Since the carb is correct for the car, you don't need to buy it, but getting a copy of Cliff Ruggles' "How to Rebuild and Modify the Quadrajet Carburetor" is very informative and has good tips on rebuilding the Q-jet. And, you might even improve it [per Ruggles' tips] from the original factory build.
Hand tools, a clean workbench and a good light source...along with a can of Carb Cleaner....should be all you need.
Old Dec 18, 2011 | 09:02 PM
gcusmano74's Avatar
gcusmano74
Also look at Doug Roe's book on the Quadrajet. After you read both of them, you will be better informed that 99% of the population.
Old Dec 19, 2011 | 08:10 AM
hwcoop's Avatar
hwcoop
It would be better to get a performance rebuild kit from Cliff's Performance as the chain store kits tend to be old stock rubber pump seals that don't stand up to new fuels as well they are a more generic kit that fit anything from pickup trucks to dads Impala. Cliffs kits come with assortment of performance parts..springs, accelerator pump, idle mixture screws etc...well worth it
Old Dec 19, 2011 | 09:33 AM
7T1vette's Avatar
7T1vette
Cliff's kits are fine. But Echlin kits do not use 'old rubber' seals. You might get that at 'the Zone' or other hi-volume chain stores, though.
Old Dec 19, 2011 | 09:22 PM
MosportGreen66
The carb was professionally rebuilt. I believe the timing in the car has to be set. There is also a vacuum leak as there is a slight whistle at idle (base plate gasket) and upon shutting off the car there is a hissing as pressure is realized....
Dave
Old Dec 21, 2011 | 10:12 PM
bhk2's Avatar
bhk2
Originally Posted by MosportGreen66
Hi Guys,
Thanks,
Dave
where did you get your carb, or did you just have it rebuilt?
thanks,
To 69 QJet
