Starter Connections
Old Dec 20, 2011 | 10:47 AM
babbah's Avatar
babbah
Default Starter Connections
Besides the large battery cable positive lead to the starter solenoid- mine has one terminal that has BOTH the battery gauge lead with fuselink and the battery 12v lead to the horn relay with fuse link. (2 connections)
Is this the way the factory installed made the harnesses - with one terminal with both of the fuse links connected to it?
The schematics show the two individual terminals that both each connect to the starter solenoid with the large battery cable (3 connections) instead of what I have (2).
What is correct?
Thanks All! Happy Holidays
Old Dec 20, 2011 | 11:09 PM
Rontech's Avatar
Rontech
Default Starter wires
What is correct?
Hi,
What year is your vette? Here is the wire hook up on My 1970 vette. Hope this helps.
Ron
Old Dec 20, 2011 | 11:19 PM
Cactus Dave's Avatar
Cactus Dave
Originally Posted by Rontech
Hi,
Ron
Does your 70 Vette have points?
Old Dec 20, 2011 | 11:30 PM
Rontech's Avatar
Rontech
Yes I have points at the present time.
Ron
Old Dec 20, 2011 | 11:49 PM
Cactus Dave
Ron
I too was curious about the connections, when I pulled my motor out I disconnected them ... but failed to remember 5 months later when I put everything back together. I have 4 wires... Big battery lead, big fusible lead, and 2 smaller leads. I did a little investigating and I should only have 3 leads (77 vette HEI). The extra lead I have no clue what it is, I went ahead and connected it to the S side of the solenoid with the other small lead.
Old Dec 21, 2011 | 12:18 AM
Rontech's Avatar
Rontech
Cactus Dave,
I guess the wiring changed somewhere along the line. I'm retired now and was thinking of moving down to the Phoenix area. How is it durning the summer months? LOL
Ron
Old Dec 21, 2011 | 01:18 AM
Cactus Dave
Cactus Dave,
Ron
When the points disappeared the wire on the "I" side (the yellow one in your pic) went away.
Summer months are fine down here, I don't even have AC, but I do have this...
Old Dec 21, 2011 | 01:36 AM
Rontech's Avatar
Rontech
Default Thanks for the picture
Cactus Dave,
The picture is great - you have a beautiful view. Thanks for the info!
Ron
Old Dec 21, 2011 | 02:41 AM
babbah's Avatar
babbah
Hi,
Ron
Mine is a 1967 Vette
Old Dec 21, 2011 | 07:11 AM
7T1vette's Avatar
7T1vette
On the '69-'74 C3's (which still have points in the ignition system), you should have both the yellow and the dark colored small wires going to the solenoid. And the solenoid should have 4 connections: the main power IN stud, the main power OUT screw mount at the bottom, and the 2 small studs on either side of the cover.
One of those small studs is labeled "S" and is for the wire coming from the ignition switch. The other is the "R" wire which runs to power the coil during the engine start sequence. When the ignition key returns to the "run" position, that "R" wire no longer has power; the coil gets fed via the resistance wire coming from the fuse block connector to the coil terminal. (There should be two wires connected to that coil [power IN] terminal.) The current level in this wire is reduced so that it doesn't burn up the coil from seeing a continuous 12vdc on it.
{Note: Some folks believe that resistance wire is to reduce the voltage to the coil. While that does happen, it is really placed in the wiring because of the current limiting characteristic of that resistance wire.}
Old Dec 21, 2011 | 04:11 PM
Blue73Shark's Avatar
Blue73Shark
Great explanation 7t1vette. About a year ago, I discovered my S and R wires were reversed. After correcting, I have not had the starter "heat soak" problems that were present when reversed.
To Starter Connections
