72 Corvette Wheels Locked
Old Dec 28, 2011 | 10:08 PM
cams1106's Avatar
cams1106
4th Gear
Default 72 Corvette Wheels Locked
I'm in the process of restoring 72 Corvette, has not been driven for 27 years. I have replaced dry rotted tires and have removed all 4 calipers to rebuild. After removing brakes when I tried to move car it feels like the wheels are locked, clutch may be frozen to flywheel but car was in neutral....any ideas what the problem might be? Engine will not start so I need to roll car onto trailler to transport to shop.
Old Dec 28, 2011 | 10:15 PM
1986coupe's Avatar
1986coupe
Could be any of the following. Seized wheel bearing. Seized u-joint. Problem inside the transmission.
Did you remove the parking brakes on the rears?
Old Dec 29, 2011 | 06:20 AM
cm2dinger's Avatar
cm2dinger
It could also be your rear diff.
Old Dec 29, 2011 | 08:16 AM
rbowman's Avatar
rbowman
Drop the drive shaft to the transmission, this will help start to isolate the issue. If it rolls its the issue is forward the rear axle if it doesn't the issue is in the axle or bearing.
Old Dec 29, 2011 | 08:33 AM
Tom454's Avatar
Tom454
This happened to me with the first Corvette I purchased... C2... basically same brakes as C3... the parking brake cables were rusted solid with the parking brake applied. The pb shoes and hardware were also rusted, but the cables were the primary culprit.
Old Dec 29, 2011 | 09:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 1986coupe
...Did you remove the parking brakes on the rears?...
Originally Posted by Tom454
...parking brake...
Parking brake.
Old Dec 29, 2011 | 09:46 AM
7T1vette's Avatar
7T1vette
You need to remove and lube/refurbish ALL of that 'stuff' anyway. New wheel bearings (in front), if they are rusted/frozen, new U-joints, etc. You will not be lucky enough to just drive it away.
Old Dec 29, 2011 | 11:03 AM
cams1106's Avatar
cams1106
4th Gear
Lots of great ideas, I was thinking that it might be the u-joints etc but had not considered the parking brake, probably the best solution is to tackle them one at a time...thanks guys for all the replies!
Old Dec 29, 2011 | 10:19 PM
Sunstroked's Avatar
Sunstroked
My 72 was last driven in 94. I bought the car and dismantled it for a full restoration. PB could be the issue, but old dried up grease in wheel bearings and u joints could contribute to the problem. Also found that my diff. carrier bearings were pitted and would have been a problem had I not rebuilt it.
To 72 Corvette Wheels Locked
