77 Headlights Won't open
Old Jan 7, 2012 | 11:42 AM
Milo3156's Avatar
Milo3156
Cruising
Default 77 Headlights Won't open
I have a 77 vett that i just picked up and from the begining the headlights will not open. i have gone through what i think is 90% of the vacuum lines and found nothing wrong. looks like the guy before me recently replaced them. Is there another way to troubleshoot this issue? would it be a regulator, acuator.... any help would be appreciated.
Old Jan 7, 2012 | 12:14 PM
Alan 71's Avatar
Alan 71
Hi milo,
There are quite a few reasons that your lights flip up....or don't. It's very rarely the vacuum hoses themselves, (unless their not hooked up in the proper way), it's rather the switch, relay or actuators.
If you click on the second 'sticky' at the top of this list of threads, you'll see a link to headlight trouble shooting information.
I'd think you could start by going through that.
Good Luck!
Regards,
Alan
Old Jan 7, 2012 | 02:34 PM
Peterbuilt's Avatar
Peterbuilt
Here's a quick and easy troubleshooting guide.
http://www.corvette-101.com/vacuum.htm
Many times the seal in the actuators is bad so check them first.
Old Jan 7, 2012 | 03:16 PM
scottyp99's Avatar
scottyp99
This link is very helpful, too.
http://forums.corvetteforum.com/c3-t...tem-works.html
edit: Oops! this is the link that Alan 71 recommended, I should read more carefully.
Scott
Old Jan 7, 2012 | 06:27 PM
Milo3156's Avatar
Milo3156
Cruising
After running a few test with a vacuum pump i have come to the conclusion that the left actuator diaphram is bad. do you guys know if one auctator being bad will cause both lights not to raise and lower when switch is pulled?
Thanks for all the help!
Old Jan 8, 2012 | 01:38 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Milo3156
After running a few test with a vacuum pump i have come to the conclusion that the left actuator diaphram is bad. do you guys know if one auctator being bad will cause both lights not to raise and lower when switch is pulled?...
No. Each side has an actuator. Have you checked the relay for the left side?
Do the lights open with the over ride?
Old Jan 17, 2012 | 07:37 PM
Milo3156's Avatar
Milo3156
Cruising
After changing both seals and boots on both actuators I still can't get the lights to raise when I turn the lights on. What's a good test to do on the relay switch? Do those go bad?
Old Jan 17, 2012 | 08:09 PM
Sideways73's Avatar
Sideways73
I have been looking at installing electric motors for my headlights to be done with the enivitable lazy eye syndrome.
Old Jan 17, 2012 | 08:28 PM
scottyp99's Avatar
scottyp99
Why not just fix what's wrong with the existing system? It works great unless it's busted.
Scott
Old Jan 17, 2012 | 08:32 PM
scottyp99's Avatar
scottyp99
Have you read the article in the link and followed it's instructions? I'm a knucklehead who can barely tie his own shoes without help, and I didn't have any trouble understanding it.
Scott
Old Jan 18, 2012 | 01:43 PM
75vetteman's Avatar
75vetteman
From: some hole in the ground town- camp verde:) arizona
i just did a search n came up with this website. hope it helps. explains lots of tests that can be done to determine the cause(s)
To 77 Headlights Won't open
