Guys, if the vapor separator is bad and fuel is going down the line does it trash the vapor canister? (hope not, I just replaced it!)
I've got a '73 that reeks of gas when the tank is very full and based on what I'm reading here I think it's one of 3 things:
1. I'm over filling the tank and the separator isn't doing it's job
2. There are hoses or gaskets at the top of the tank that have gone bad or...
3. Bad gas cap.
Although I can smell gas at the cap when I raise the fuel cap door, once the the gas tank gets down a ways the smell goes away. When the tank is topped off the smell is REALLY strong but by the time the fuel gauge drops to F it goes away.
I'm not positive, but I think the fuel vapor separator is only there to STOP fuel leaking out of the tank during a 'rollover' accident. It shouldn't have any affect on [liquid] fuel getting to the canister.
If that isn't correct, someone else can chime in.
Perhaps the vacuum operated switch on the vapor canister is not working properly. Or, maybe you've hooked up the vacuum lines incorrectly to that vapor canister.
3. Bad gas cap.
The hoses are the first to go. With a full tank the brittle hoses will weep initially then leak as they break down over time. I was surprised at how brittle mine were when I replaced them.
The hose to the vapor separator will usually go bad before the separator. The separator is simply a big plastic check valve which allows vapors but not fuel to pass to the vapor canister. The check valve has a simple "ping pong ball" inside that floats when fuel rushes in and stops the liquid from going further. When the separator goes bad it's usually due to a cracked housing which lets fuel leak out when the tank if full. If raw fuel gets to your canister I doubt it would require replacing as it's function is to collect tank vapor for reburn by the carb. The vapor would frequently have the opportunity to condense into liquid while in the canister throughout the years depending upon weather/temp conditions which naturally occur.
I've never had a gasket nor cap leak.
So, I'd check your hoses. They're not really that hard to get to.
If there's a leak in that area, it drips right on top of the hot muffler. Beware.
Don't over look the fuel vapor separator. With a full tank on a hot day mine allowed raw fuel to travel
to the charcoal canister. The replacement was also defective (leaked fuel), the 2nd one worked.
When I parked my new 73 with a full tank on an incline, nose down, fuel would leak out of the canister. So I stopped filling the tank right up to the top.
I don't think these vapor seperator worked that great right from the start. As suggested above, it probably was there for roll-overs only.
I checked my original during my body off and there is no cracks anywhere and the ball still rattles.
I fill my 73 to 1 inch below the neck and have no odor problems. Did you check to see if you have a vented cap? If your canister had been removed for a time someone may have put i vented cap on it. Just something to look at. Also as suggested before the filler neck seal might be the problem since you don't see any leaks.
Thanks, I've ordered a new cap since the old one is pretty crappy but think it's either the gaskets, hoses or the separator. Unfortunately the weather in Colorado went to hell so the snow's flying, the temps have dropped and the Vette is nose into the garage so this project is going to wait for better weather when I can take her out for a cruise to burn off the gas in the tank.
For what it's worth, I did find this article which seems to describe the process of dropping the tank.
From: Las Vegas - Just stop perpetuating myths please.
What are u running for the return line?
If u have a constant recirc from an EFI and electric fuel pump u can over-pressurize the tank and lines with a sealed cap. The vapor sep is to block flow at atmospheric press only.
Yes u can fill the Vapor Cannistor will a full tank of gas and a good right turn.
cardo0
