1971 LT-1 questions from inspection report
Old 01-13-2012, 11:54 AM
Mike Ward
Mike Ward's Avatar
Originally Posted by 1974ta
You CAN also Top Flite with a 100% Paint Deduction. There was another thread on the NCRS TDB discussing this as well.
This is very true- but given the expected heavy point loss for paint (45+40 points) the remainder of the car has to be pretty well perfect. I think the amount of work and money needed to address the issues aside from paint is more than the OP is willing to undertake, if I understand correctly.
Old 01-13-2012, 12:27 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,470 Likes on 1,249 Posts
Cruise-In II Veteran
Originally Posted by dmayhew
...I was not aware that no work was done on Sundays...
The UAW saw to that. Saturdays, yes. Sundays, no. The line also did not run on most of the major national holidays.
...As for the assumption that the motor pad may be a June date, which is what was wrote above, that becomes an issue, inthat below the Alternator date above it is stated the car was assembled in May...
There is no number beneath the alternator; wrong side of the engine. The block stamp pad is below the passenger's side head (right side) below the AIR pump.
...That is why I was asking if he would share the VIN sequence #...
You need the VIN. To be honest, there is nothing to "share." If the seller doesn't provide the VIN, pass on this car.
Old 01-13-2012, 12:58 PM
Mike Ward
Mike Ward's Avatar
I think the reference was to the text in the original post way above which mentioned that this was a May built car.
"Alternator part number 1100950
42 amp
12 v neg
1 L 22 date code
1 = year 1971
L = month November
This is built after the car was built in May."
Without clarification on the car build date and VIN and trim tag date, the discussion might all be moot and then go mute.
Old 01-13-2012, 01:07 PM
Easy Mike
Easy Mike's Avatar
Originally Posted by Mike Ward
...I think the reference was to the text in the original post way above which mentioned that this was a May built car....this is built after the car was built in May."
[/I]...
Ahhh! I see it now, but missed it the first two or three times through the text.
Car assembled in May; engine not assembled until June.
I now smell the rat.
Old 01-13-2012, 06:14 PM
1974ta
1974ta's Avatar
I totally agree Mike. Just wanted to let him know that it is possible.
My 70 was in similar shape as this LT-1 and I can confirm that it will cost him at least two to three times as much as he thinks to Top Flite.
Bill
Old 01-15-2012, 09:00 PM
TSAGG
TSAGG's Avatar
Sorry for delay everyone, crazy weekend. I have spoken to two of the previous owners who vouch for the correctness of the numbers. I have a call with the inspector tomorrow to hopefully confirm that there is just a typo on the report codes causing some of the confusion and questions.
Thanks all for the responses thus far!
Old 01-16-2012, 01:51 PM
Easy Mike
Easy Mike's Avatar
Post the VIN.
Old 01-16-2012, 02:05 PM
TSAGG
TSAGG's Avatar
194371s119561
Old 01-16-2012, 03:01 PM
Mike Ward
Mike Ward's Avatar
Car was completed around June 16-18th
Old 01-16-2012, 03:12 PM
Dick Whittington
Dick Whittington's Avatar
-Damage of a 1/8” diameter size hole on the driver side above the String Ray front fender emblem.(3 piece replacement nose at some point
Am I reading this to mean it has had a front clip installed? If the clip is not manufactured using correct appearing materials and pieces, you are looking at $5k for the parts plus installation.
Old 01-16-2012, 03:26 PM
Mike Ward
Mike Ward's Avatar
Dicky!
What brings you here?
Old 02-10-2012, 07:04 AM
TSAGG
TSAGG's Avatar
Well. I bought the car! Hopefully will have in my garage by early next week. Then I can start cleaning everything up. Thanks all for the responses!
Old 02-10-2012, 08:27 AM
  #33
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi T...,
GOOD FOR YOU!!!!
You should be in for some FAST fun!
Good Luck!
Regards,
Alan
Old 02-10-2012, 10:46 AM
  #34
billla
billla's Avatar
St. Jude Donor '14
Lucky guy - it's a beautiful ride!
Quick Reply: 1971 LT-1 questions from inspection report
