Chain help
Old Jan 16, 2012 | 10:11 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Lots of misinformation here. People there is a difference between ignition timing and valve timing. The Ignition timing curve was not set up for performance by GM but was set for optimal emmisions. Recurving the distributor is the best way to pick up some performance not just setting your ignition timing 4 degrees advanced. Advancing your valve timing might give you a little more bottom end but will sacrifice power up top and likely reduce ET's. Best off getting a cam that is designed to work in the powerband that matches your compression, driving style and gearing.
Old Jan 16, 2012 | 10:47 AM
7t9l82's Avatar
7t9l82
yes lots of misinformation. the L-82 cam is the350/350 cam. it was originally designed to be run straight up. just like the ignition they retarded the timing there too. that cam goes nicely to 6000 r.p.m how high. do you want to go? if you think ignition timing helps you should try this. just the increased cylinder pressure helps. your right about cam timing but there are other factors at play here.
Old Jan 16, 2012 | 03:50 PM
69 Chevy's Avatar
69 Chevy
Originally Posted by aussiejohn
...so it looks like I will have to get a new timing chain set with adjustable keyways.
Not necessarily. You can buy an inexpensive camshaft timing offset bushing kit like this one, but there are other brands available too.
http://www.summitracing.com/parts/HRS-94505
Old Jan 16, 2012 | 04:44 PM
aussiejohn's Avatar
aussiejohn
Default Now, where can I get one?
69 Chevy,
Thanks for that, I'll now have to try to find a set in Australia. If not, I have Summit's number.
Regards from Down Under.
aussiejohn
Old Jan 16, 2012 | 05:15 PM
billla's Avatar
billla
St. Jude Donor '14
...along with the machine shop to drill out the cam gear. I'd expect by the time you're done a Cloyes with multiple keyways will be cheaper.
Bushings are typically used when fine tuning of cam timing is required for racing in a known RPM range.
Would still like to see some documentation that the cam was factory-installed retarded...
Old Jan 16, 2012 | 05:48 PM
scottyp99's Avatar
scottyp99
Originally Posted by 75vetteman
to advance u should just need to turn the distributor as u check the marks with a timing light. i got a cheap light from autozone that works quite well for this.
my ? is will this cause me to need to make changes to my idle speed?
Dude, they are talking about advancing the camshaft/valve timing, not the ignition/spark timing. If you have questions about spark timing, here's a great article about it:
http://forums.corvetteforum.com/c3-t...long-post.html
Scott
Old Jan 16, 2012 | 09:37 PM
75vetteman's Avatar
75vetteman
From: some hole in the ground town- camp verde:) arizona
thanx. confusion came into play in that i've never herd of changin valve/camshaft timin n assumed it another name for the same thing. i must first be yung n stupid fore im old n wise. that fits me perfectly
Old Jan 20, 2012 | 10:26 AM
69 Chevy's Avatar
69 Chevy
I don't understand why the services of a machinist would be required just to enlarge the hole in the cam gear to install these bushings? Perhaps if the only tools at your disposal were a claw hammer and wood chisel.
Old Jan 21, 2012 | 02:58 PM
billla's Avatar
billla
St. Jude Donor '14
Have you personally done it?
Regardless, wrong item for the application.
Old Jan 28, 2012 | 02:47 AM
Solid LT1's Avatar
Solid LT1
7t9,
I knew that turning the dissy would not advance the cam, so it looks like I will have to get a new timing chain set with adjustable keyways. It's a pity, as I just had the harmonic balancer replaced - the outer ring had slipped and I had to time it by ear.
I'll leave it alone for the time being, but will do this in the future, probably during winter (June-August). Thanks again for highlighting this.
aussiejohn
Good news Mate! some of the better timing sets are being made in OZ no import taxes
John do yourself a favor and if you decide to play around with distributor advance springs, get an MSD distributior advance spring kit. All the other kits now seem to contain Chinese made JUNK parts. If your playing around with your 4 speed cars don't go too light on the advance springs, it is better to keep a medium spring in the distributor, you will hear detonation at lower RPM ranges when flooring the throttle when you have gone too light.
Here's a link to the kit you need: http://www.streetsideauto.com/p/msd-...GoogleShopping
Hows the Pro Stock project of Bruno's going? haven't talked with Bob since it was shipped off to OZ. Hope he's wearing some adult diapers when he launches it for the first time, I think he'll need them. 2.75HP per cu/in is pretty serious territory to play with.
