Chain help
Old Jan 14, 2012 | 10:23 AM
Toolman1953's Avatar
Toolman1953
Default Chain help
Good morning fellow gear heads, Doing a clean up and dress up on my 77 so I pull the timing cover off to replace with the chrome one and I see a nylon cam gear. Well its got to go so I buy another set from my local NAPA and in comes a Cloyes Heavy duty performance Napa part# 10-3023X. It’s a double chain and gears any problems doing the install? As far as fit and cover clearance? And I am going to assume that the standard clocking of the crank gear rather then the advance or retarded settings is the way to go its not a race car just a summer time weekend play toy. Thanks these are the kind of questions I promised to plague you with when I signed up to the forum
Old Jan 14, 2012 | 10:56 AM
7t9l82's Avatar
7t9l82
the factory retarded the cam 4 degrees for emissions reasons. they were designed to run straight up. advancing it 4 degrees puts the cam where it should be. i personally would not put it back any other way. you wont be disappointed i did my 79 and back when my 78 was new i did it too.
Old Jan 14, 2012 | 11:22 AM
daanbc's Avatar
daanbc
St. Jude Donor '12
I'll be installing the same chain and replacing my cam in the very near future. Should I advance the gear also? Or will the new cam take care of this?
Old Jan 14, 2012 | 11:29 AM
mds3013's Avatar
mds3013
Hey, Dave. If it is not the stock cam I think you should time it at 0degrees. My new Lunati has transformed my stock L82. It will burn the tires from a dead stop on new concrete road surface. Stock L82 cam would not turn a tire on any dry surface. mike...
Old Jan 14, 2012 | 11:56 AM
daanbc's Avatar
daanbc
St. Jude Donor '12
That was my thought also. They say the new cam has timing advance built into it. My L48 spins the tires now at a stand still start. Did you have your timing/distrib. set right before? You should have been able to do a spin.
Old Jan 14, 2012 | 01:23 PM
mds3013's Avatar
mds3013
The L82 cam, in '77, is a total DOG. High RPM only. No torque whatsoever. Yes all was correct before. The improvement was due to the cam. mike...
Old Jan 14, 2012 | 05:40 PM
Solid LT1's Avatar
Solid LT1
Check the cam gear and make sure it clears the front of the block. Shouldn't be a problem if your blocks original but, better to be safe than sorry.
Old Jan 14, 2012 | 06:16 PM
billla's Avatar
billla
St. Jude Donor '14
Shouldn't be any issues with clearance under the cover or at the cam gear boss - but certainly check carefully during mock-up and/or final ***'y.
Generally, a cam should be installed "straight up" with no advance/retard at install via the crank gear. If you want different advance...buy a different cam. So many off-the-shelf choices these days there's not a lot of reason to do this any more.
Generally, changing the advance moves the power peaks - about 500 RPM for each 4 degrees of advance. Advancing the cam moves it down, retarding the cam moves it up. There are other side effects as well - so if unless you're doing it for a specific reason and you understand what's happening...don't.
Old Jan 14, 2012 | 07:19 PM
gofastvette's Avatar
gofastvette
unless this is a race car in disguise and running on the record, I agree with the above statement...Straight up is your best bet....
Old Jan 14, 2012 | 09:05 PM
Sean77's Avatar
Sean77
I put an Edelbrock double roller chain on my '77 and had no fitment issues.
Old Jan 14, 2012 | 10:51 PM
Tom Sarno's Avatar
Tom Sarno
When you remove the cam sprocket you will see three oil galley plugs. Square up the radius above the middle plug with a grinder if it is close to the back of the new sprocket being careful not to let shavings get into the oil pan.
Old Jan 14, 2012 | 11:16 PM
Solid LT1's Avatar
Solid LT1
Edelbrock dosent make timing chains or grind camshafts. They only repackage off the shelf products and mark them up considerably for the re-boxing process they perform. You can find most Edelbrock grinds in a Melling engine parts catalog if you know where to look. They are about 1/2-2/3rds the price of the Eldelbrock items.
Old Jan 15, 2012 | 03:40 AM
Ralphbf's Avatar
Ralphbf
Let's see some numbers then.
I've been very happy with Edelbrock timing gears and chain.
Would be even happier at 1/2 price.
Ralph
Old Jan 15, 2012 | 10:09 AM
69 Chevy's Avatar
69 Chevy
It's going to be noisier than the nylon gear.
Old Jan 15, 2012 | 07:19 PM
aussiejohn's Avatar
aussiejohn
Default 1974?
7t9,
One thing I love about this Forum is that I can always learn something new from people such as you. I flat out did not know that the factory installed the cams retarded and I thank you for educating me. I bought a '74 L48 from Solid LT1 two years ago and am very happy with it but if there's some "free" horsepower to unleash, I'm all for it.
Apart from the obvious disassembly of the balancer, water pump and timing cover, exactly how does one go about advancing the cam 4 degrees? Unless Eric chimes in and says otherwise, I'm presuming that the cam is the stock factory one.
Once this is done, the dissy will need to be altered, and Lars told me that the smart thing to do is fit lighter advance springs to bring full advance in at a lower than factory rpm. Your comments?
I feel sure that few here knew of the factory retard situation, so many can learn from your response. Thanks, and.........
Regards from Down Under.
aussiejohn
Old Jan 15, 2012 | 08:07 PM
75vetteman's Avatar
75vetteman
From: some hole in the ground town- camp verde:) arizona
i'm with the aussie. i had no idea it was retarded for emissions purposes only. come summer when i can afford to tinker with the car with no worries of needin it i'll try runnin it at 0 degrees. right now i need it 4 college 3 days a week at just over 100 mile round trips.
dependable as always!!!
Old Jan 15, 2012 | 08:13 PM
75vetteman's Avatar
75vetteman
Originally Posted by aussiejohn
7t9,
aussiejohn
to advance u should just need to turn the distributor as u check the marks with a timing light. i got a cheap light from autozone that works quite well for this.
my ? is will this cause me to need to make changes to my idle speed?
To Chain help
Old Jan 15, 2012 | 08:30 PM
billla's Avatar
billla
St. Jude Donor '14
Can someone post a shop manual reference or comparative photo showing where the L-82 cam is factory-installed 4 degrees retarded? Would just like to see this as it's new to me
Old Jan 15, 2012 | 10:29 PM
7t9l82's Avatar
7t9l82
you absolutely can not advance or retard a cam by twisting a distributor.you get a timing chain set with adjustable keyways.
Old Jan 16, 2012 | 03:14 AM
aussiejohn's Avatar
aussiejohn
Default That's what I thought.
7t9,
I knew that turning the dissy would not advance the cam, so it looks like I will have to get a new timing chain set with adjustable keyways. It's a pity, as I just had the harmonic balancer replaced - the outer ring had slipped and I had to time it by ear.
I'll leave it alone for the time being, but will do this in the future, probably during winter (June-August). Thanks again for highlighting this.
aussiejohn
