Borgenson Steering Box
Old Jan 14, 2012 | 09:30 PM
glackore's Avatar
glackore
Default Borgenson Steering Box
Got my kit a couple of days ago. I'll be doing the swap in the coming weeks. Can't wait to feel the difference! Should help me improve my autocross times!
Old Jan 14, 2012 | 10:30 PM
682XLR8's Avatar
682XLR8
let us know how the install goes
You're gonna like it
Old Jan 14, 2012 | 11:12 PM
milo30's Avatar
milo30
I've heard of these but don't know much about them. They are direct bolt ins that will give you a better steering ratio and no leaks right? With that better gear ratio does it make the steering easier to turn? Mine is a little harder than it should be but I need an alignment and hope that will fix it. If not and this will I might be doing one of these upgrades too.
Old Jan 14, 2012 | 11:32 PM
682XLR8's Avatar
682XLR8
Not sure if you've seen my thread on the Borgeson box, here it is, it should answer some of your questions:
http://forums.corvetteforum.com/c3-t...g-install.html
Old Jan 14, 2012 | 11:58 PM
BigBadBorry's Avatar
BigBadBorry
I found it a quick and relatively easy install, even with Hooker headers/ side pipes. The difference is quite amazing.
The only down-side, the biceps were really starting to bulk up from the effort, it's so easy now all that hard work may be obsolete )
Old Jan 15, 2012 | 08:50 AM
redwingvette's Avatar
redwingvette
I installed mine last fall. It takes a little time to make sure the steering wheel is aligned right. Fairly easy install.
Instillation
Old Jan 29, 2012 | 07:47 PM
glackore's Avatar
glackore
Completed the install and thought I'd post a few pics. A few comments:
1. The job was tougher than I thought it would be.
2. The old parts came out OK but the new ones were a bit of a struggle.
3. The column collapsed easily but I went about 1/2" too far. It isn't too hard to get it back out.
4. The Borgenson box is larger in the "head" than the stock unit making it a tighter squeeze with the Hooker Comp side exhaust.
5. I didn't remove any exhaust (PIA) so I worked around it (PIA!).
6. Had to re-adjust the clutch as the linkage ran into the steering box.
Now, it is time to get an alignment!! Should work great!!!!!!!
Old Jan 29, 2012 | 07:57 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
That's the first I've seen or heard of an issue with the clutch z-bar and the Borgenson box. What year is the car and just how much interference did you have?
Old Jan 29, 2012 | 08:23 PM
PeteZO6's Avatar
PeteZO6
Check his first picture. It looks like the clutch linkage is not stock! That could account for the interference. I didn't have that issue at all with my stock clutch linkage.
rpoL98's Avatar
rpoL98
also, did the pitman arm seat on the shaft adequately? to get enough threaded shaft sticking through for the nut & lockwasher to engage thoroughly?
I read that was an earlier issue...
thanks for the pics & commentary.
Old Jan 30, 2012 | 08:51 AM
glackore's Avatar
glackore
The clutch linkage is not stock - a Speed Direct replacement. I adjusted the top shaft all the way short and lengthened the bottom shaft.
The threads don't come quite as far thru the nut/washer as the stock unit but it is close. I figured I would re-check after driving for a few miles to be sure the nut is secure. It should be - I torqued on it with my breaker bar quite hard several times.
Thx, Gary
Old Jan 30, 2012 | 11:43 PM
Rebelrob's Avatar
Rebelrob
Looks good Gary...
Also looks tight with the header tube. I would like to have this, but I think I am S.O.L. with a BB. I had to ding the holy hell out of my header tube to get it past the stock steering box.
Try the at home alignment and steering wheel center job, its not that difficult. It is a PIA, but do able.
Old Jan 31, 2012 | 07:56 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I've got it on my car with 2-1/8" Hookers and exhaust ports raised .600". Fit pretty nice overall. I did need to use their u-joint instead of the rag joint to clear the #7 header tube but no biggee. I did an article in Corvette Enthusiast on it.
JIM
Old Jan 31, 2012 | 08:26 PM
glackore's Avatar
glackore
Now that I've driven the car and gotten an alignment I feel a vibration. I'll be re-checking all of the fasteners, including the pitman arm. I spec'd -1 degree on my camber as I want to hit the corners as hard as I can with as much rubber making contact with the pavement.
427Hotrod - I like the u-joint. I may switch to it just so it looks better.
Thx, Gary
Old Jan 31, 2012 | 08:42 PM
tyancey00's Avatar
tyancey00
427,, which one of the lines goes to the hi pressure side of the power steering pump?
Old Feb 2, 2012 | 10:37 AM
glackore's Avatar
glackore
tyancy00
FYI - it is the one on the bottom, nearest the fenderwell in the pic.
Old Feb 2, 2012 | 10:56 AM
ezobens's Avatar
ezobens
This comment worries me-
How did you collapse the column?!
The only way I could see doing that is if you sheared the plastic pins in the shaft to telescope the shaft inward.
This is a safety feature to allow the column to collapse in the event of an accident so that the column doesn't skewer you in a head on.
Is this what Borgeson instructs customers to do?
Elm
To Borgenson Steering Box
Old Feb 2, 2012 | 12:38 PM
aussiejohn's Avatar
aussiejohn
Default Careful, buddy!
[QUOTE=glackore;.
Thx, Gary[/QUOTE]
Gary,
Remember this: The Corvette body is attached to the separate chassis with rubber mounts and there can be movement between the two. This potential movement is why GM used a rag joint in the first place. A uni joint will not allow for any movement here and you could well have alignment issues if you went this way. This would cause excessive wear on the lower steering column bearing, the steering box itself, etc.
Think carefully before you go this way.
Regards from Down Under.
aussiejohn
Old Feb 2, 2012 | 12:49 PM
VetteV8's Avatar
VetteV8
Elm
Indeed.
Cor
Old Feb 2, 2012 | 12:51 PM
aussiejohn's Avatar
aussiejohn
Default Not quite correct.
Elm
Elm,
Yes, the shaft (and column) is designed to collapse in a frontal collision to protect the driver, but there is nothing unsafe going on here. The plastic pins were inserted in order to keep the shaft at a finite length for ease of assembly on the production line.
Shearing them will not affect the shaft's ability to collapse and will not compromise the car's safety in any way. Two inches of "collapse" will only give more contact between the inner and outer steering shafts which could be considered safer than stock.
Granted, there is about two inches less of "collapsibility", but there is still plenty left. Don't worry about it.
To collapse the column, just place a lump of hardwood or aluminum over the splined end and hit it with a big hammer. You might want to place some Vise Grips on the shaft about two inches down from the bearing so that it won't collapse too far if you overhit it.
aussiejohn
