76 Windshield Defroster
Old Jan 16, 2012 | 10:44 AM
hgoodwiniii's Avatar
hgoodwiniii
Default 76 Windshield Defroster
Hi we are starting to put interior back together for 76 and noticed a gap between the duct that sits right below the dash pad that directs air defroster air to the windshield and the duct that provides air from the bottom at it's base. The gap is about 3 inches. I'm trying to determine if the gap should be there or if we are missing a connector part? Any ideas? Thanks.
Old Jan 16, 2012 | 12:14 PM
blckslvr79's Avatar
blckslvr79
I'd say you are missing something.
Been too long since I had mine apart to tell you what though.
Old Jan 16, 2012 | 03:41 PM
dembo's Avatar
dembo
3" is alot. I don.t have a close up pic, but the gap on mine was about 1/2" max. I tried several ducts and they where all about the same. Not much moving around possible so closed it with alu tape ...
Nick
Old Jan 16, 2012 | 08:06 PM
hgoodwiniii
I thought mine was wider but it's is actually about a 1/2 in.m as well. I will tape it down with aluminium tape, too. I did crank the car and run the defroster and air does flow there even though that gap exists. Interesting! I'm assuming any hardware store should have the tape? Thanks.
Old Jan 16, 2012 | 09:56 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
1/2" Gap is normal.. hate to say it.. Dembo's solution is a great mod for a better defrost...
Old Jan 17, 2012 | 10:09 PM
hgoodwiniii
I read the owner's manual again and seems the gap was left there on purpose. The manual says (page 2-19 under "DEF") "If the control is positioned between "HTR" and "DEF", air flow is divided between floor and defroster outlets. Perhaps this is the route for floor heater air to travel? Who knows. I'll decide what to do in the am. Thanks.
Old Jan 18, 2012 | 09:47 AM
jcloving's Avatar
jcloving
Mine had a half inch gap. I used aluminum tape to seal it up. Now it works well....not that I will ever need it.
To 76 Windshield Defroster
