Differential side yoke play?
Old Jan 25, 2012 | 05:24 PM
zwede's Avatar
zwede
If it makes a difference, I agree too. I would not worry one bit about 0.025" play.
Old Jan 25, 2012 | 05:30 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by tracdogg2
Everyone's always asking for numbers so I'm going to stick my neck out and post guidelines. If anyone has an opinion or thought go ahead and post so that we can use these numbers for future questions.
End play:
Less than .025 No problem
.025 - .050 Starting to wear, consider inspection
.050 - .100 Beyond normal cluth wear, possible clutch damage
and/or heavy stub axle wear. Needs attention
.100-.150 Excessive wear and/or damage. Needs immediate
attention.
.150 -.200 Severe wear and case damage
Mike
Sounds reasonable.
Old Jan 25, 2012 | 06:37 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
End play:
attention.
Mike
Originally Posted by 63mako
Excellent info Mike. This is a common question and it is helpful to have someone with recognized, extensive experience commit to a guideline. This is good info to have when these guys come on here spouting that 1/4" of play is nothing to worry about as they have been running thiers like that for years and so have thier buddies with no issues.
I guess I'm just plain lucky and spouting. Anyone is welcome to come up here and have a look at my rear! I have over 90K miles on my never been opened differential with 1/4" play. I can lay down two black strips launched at 3500 rpm all day long. No noises from the rear. So, when will I expect to have severe wear and case damage? Somewhere north of 90K miles? That's a lifetime for cars built back in the day. I think our vettes are a lot more durable and reliable than what others would think. Just sayin'.
Old Jan 25, 2012 | 07:34 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Now.
Old Jan 25, 2012 | 07:47 PM
Mike Ward's Avatar
Mike Ward
I don't think it's directly related to miles. The later C3 yokes ('76 and up?) have far less case hardening than the C2 and earlier C3 yokes and as such are known to wear at an accelerated rate once the case hardening is penetrated. The 'table' proposed by tracdogg is a one-size-fits-all that does not take this difference into into account.
I was going to disagree with the level of attention required as the wear increased but feared that this would just touch off another round of 'road safety' debates. It would be nice if the reasons for wear could be determined without disassembly of the diff. The owner could then decide which repairs are required (if any) and with what level of urgency. Simple end play of a yoke doesn't mean much by itself.
Old Jan 25, 2012 | 08:07 PM
63mako's Avatar
63mako
A differential with 1/4' of play at the sideyokes has one of 3 issues.
1. Badly worn yoke ends and/or center pin
2. Trashed, broken posi clutches
3. Broken or missing C clips.
Any of the above means there is debis in the case circulating through the bearings and gears. I have posted this numerous times yet get the same responses. There is no filter for this fluid. There is no where for these shavings, fillings and pieces to go other than continuously circulating throughout the differential bearings and gears. I really don't get why this concept is impossible for some people to grasp.
I will try to make it simple. Metal fillings, shavings and chunks do not lubricate well and cause continuous wear and damage when run between gears and bearings. It is not necessary for the reason for the play to be able to be determined without opening the case. The case needs to be opened and the rear end rebuilt if it is not destroyed beyond repair.
To the OP your fine.
Old Jan 26, 2012 | 12:25 PM
noonie's Avatar
noonie
It's really a pretty simple concept.
Old Jan 26, 2012 | 01:15 PM
Mike Ward's Avatar
Mike Ward
Not sure if your question is rhetorical or if you're actually looking for an answer. Much like the huge number of owners who drive around for years with large amounts of yoke end play and are oblivious to it until they happen to jack up the car for inspection, the same differentials operate successfully for years despite the metal shavings sitting inside.
If differential bearing or gear failure was a common problem and was associated with yoke wear as a root cause, you would have a good point.
Old Jan 26, 2012 | 03:15 PM
63mako's Avatar
63mako
Really? Total failure is much different than drasticaly accelerated wear. The hardened yoke ends and hardened center pin are ground into powder. They are in the fluid. It does not sit in the bottom of the case. I have disassembled a lot of these and when the side yokes are trashed the fluid has silver sparkles suspended in it, many times it is grey from all the metal in it, and there are larger pieces and shavings sitting in the bottom but they have settled there. You seem to be a somewhat rational guy and claim to have a degree in engineering. How can you not grasp basic mechanical concepts like this? Lets leave it like this. You keep telling people this is no cause for concern and I will keep telling them otherwise. I am done. Discussion over.
Old Jan 26, 2012 | 03:24 PM
Mike Ward's Avatar
Mike Ward
Show me the massive piles of trashed diffs that failed prematurely due to contaminated oil. How is it that worn yokes are so common but failed diffs are not?
You (and others) talk a great theoretical game, but that's about it.
Old Jan 26, 2012 | 05:44 PM
45ACP's Avatar
45ACP
So you are advocating the use of ground up steel in differentials and control arms with as much as 1/4" of play.
Ok.
Old Jan 26, 2012 | 05:58 PM
Mike Ward's Avatar
Mike Ward
No, I just don't play the 'road safety- we're all going to die' games
Old Jan 26, 2012 | 06:05 PM
  #33
63mako's Avatar
63mako
Old Jan 26, 2012 | 06:59 PM
  #34
fanmanbd's Avatar
fanmanbd
Just installed a HD cover and found no shavings or metal of any kind in the lube or laying on the bottom of the case. Guess I don't even need to check my end play.
Old Jan 26, 2012 | 08:55 PM
  #35
Steve2147's Avatar
Steve2147
To keep things in prospective one should know what different people's definition of "safe" is.
Mike Ward has previously led us to believe that as long as the wheel isn't leaving the car, it's safe. In a previous thread on the subject when discussing the disadvantages of camber change due to worn yokes Mike told us that he also sees no problem with loose bushings in the lower strut.
I'll go on record as saying that I believe that looseness in the attaching points of the suspension qualifies as unsafe, regardless of whether the wheel will fall off or not.
I think .050 is plenty of wear. If I had that and the diff was still in the car, I likely wouldn't do anything with it. However, if I had the diff out for any reason and had that play I would correct it and bring it down to near .000. You wouldn't tolerate .050 lateral play in an upper ball joint why would it be okay in the upper control arm of the rear? If you're a performance enthusiast and looking the squeeze the most out of your car's handling, this would be a no brainer. Not much point in tweaking the geometry and going to any kind of high performance components anywhere and leave slop in the rear wheel like that.
Steve g
Old Jan 26, 2012 | 09:42 PM
  #36
tracdogg2's Avatar
tracdogg2
Reread post 12 about no metal in the bottom of the case.
resdoggie, Next time I get up there I'll be glad to stop by. But for now I'll be happy with pictures. Jack up the vette with the rear wheels hanging and take a few pictures where the stub axles goes into the diff.
I will do the same showing pictures of bearing races with metal shavings imbedded in them and trash in the pinion bearing cavity.
Mike
Old Jan 27, 2012 | 08:55 AM
  #37
fanmanbd's Avatar
fanmanbd
Response was for post #29
To Differential side yoke play?
Old Jan 27, 2012 | 09:36 AM
  #38
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Mike
tracdogg2, next time you are up this way let me know and we'll get together. I will be putting her up on jacks this weekend and I will post a few pics.
Old Jan 27, 2012 | 09:49 AM
  #39
71scgc's Avatar
71scgc
My diff with 100,000 mi. had 1/4" and 3/16" of endplay. Yokes worn down to c-clips, metal in fluid. Can't see where that's any good at all.
GTR1999 agreed.
New yokes installed.
Drive on them at your own risk.
Old Jan 27, 2012 | 01:55 PM
  #40
63mako's Avatar
63mako
OK, can't leave it alone. Failed differentials are very common in these cars. See how many C3 differentials are still good, not in need of rebuild and untouched @ 100,000 miles. Then compare the differential longevity in other vehicles. My 72 differential with 112,000 was trashed to the point the case couldn't be saved yet the original trans and engine were in perfect working order and the only oil leak was a valve cover gasket. Many of the 78 -79 differentials need a complete rebuild @ 50,000. These differentials have failed prematurely due to contaminated oil and worn yokes and, yes it is rampant and across the board. Many vehicles can run 200,000- 300,000 with the stock differential untouched. Not C3's. Luckily I was able to find a correct date coded differential that was rebuildable for $400.
