Do you have to have a vacuum reservoir tank? I find it interesting that the usual supply houses do not sell them. Al least not for a 68. Does anyone have a picture of one?
I do not have one on my '69. I find that I can remember to turn off the headlights prior to turning off the motor. Wiper door is long gone.
It is a cube shaped canister,approx 1 cubic foot if I remember,that mounts on rear of the driver side fender well.
Sorry,no pics.
Sorry,no pics.
So are you saying that if you had a wiper then you would need it?
The vacuum reservoir is used to maintain vacuum level...regardless of throttle being used. If you didn't have one and you went to WOT, your vacuum level would drop to nothing and the wiper door would want to close.
Is it absolutely necessary to have one? No. Is it a good idea, if you want a well-working system? Yes.
You can use about any container that will hold 20"Hg vacuum (without imploding). It just needs to be sealed, have about 1/2 cubic foot of volume, and have 3 nipple connections for vacuum hoses.
Hi AW,
If you don't come up with a tank here you might try Gee Auto Sales in Middlebury Center, Pa. (Google)
Gale Gee, the owner, is a very nice guy.
Regards,
Alan
Vacuum tanks supply energy to open the lights, heater controls PB booster, carburetion, etc.
They are a PITA to remove and intall so make sure the replacement is good before spending the time. The foot brackets tend to flex with the tank and must be persuaded for the holes to align.
What general area does it attach in a 68? That way I can go look for holes or bracket remnants.
Hi AW,
The tank mounts to the left-side inner fender.
You can see the top of the tank in this picture.
There are three 'feet'that are part of the tank, each with 2 welded nuts for bolts that pass through the fiberglass
You can't get it in or out with out moving the master cylinder out of the way.
Regards,
Alan
Since I have never had a wiper door on my car I'm not really familiar with it's operation. All I know is that without a reserve canister I have no problems with my headlights. As long as I remember to turn out the lights before I stop the engine. And it did free up a bit of room for the placement of the new fuse box. I have it mounted on the firewall to the rear of the driver side inner fender.
Hi AW,
Regards,
Alan
WOW that engine compartment looks gorgeous. Thanks for the info. Lucky for me the master cylinder is not it yet. I was actually in the process of painting it. Found out just in time.
Just as a side note. When I did the body off restoration on my '69 I decided to sand blast the vac. reservoir for repainting. I found cracks at the bottom of the stiffener depressions on both sides of the can.
I'm certain these cracks were created by over 40 years of vacuum cycling in the reservoir and the cause of vac leaks. Look for these cracks when refurbing your vac reservoir.
