I've searched the forum and can't seem to located a thread/post on how to fix the run out on the rotor.....So how is it fixed? I have a chirping noise at low speeds and with the windows down, I can hear it really well....and it stops when I just touch the brakes. Either that or I have a bird camping out in my Vert and he knows when I touch the brakes.... Any help will be greatly appreaciated.
If your brake pads have a 'wear indicator' on them, 'chirping' is the sound they make when the pads are getting worn down pretty far. Pull the wheel and check pad thickness. If you have plenty of pad and that little 'scraper' is still hitting the rotor when applied, just bend it back a bit.
With out of round rotors, the 'chirping' happens when you apply the brakes.
75 Corvette pads don't have wear indicators, unless it is some unusual aftermarket thing.
Runnout can cause chirping and is a common cause. The pad works back and forth on the pin and sings like a bird. Sort of like friction turkey call. Hey, an idea, use it for turkey hunting. A slight touch of the pedal quiets it immediately.
As for fixes, you haven't looked hard, because there must be hundreds of discussions on the subject. There are many fixes ranging from machining together like original or shimming.
The first thing I did was mount the rotor on the spindle. I used some Heavy duty Grade 8 washers on the studs. Then evenly torqued the lug nuts just like I would if I were mounting the wheel.
Then I used a magnetic base dial indicator to measure the runout near the outside diameter of the rotor. I marked the rotor face low spot with a felt pen.
I removed the rotor and installed shims over 3 wheel studs. I used regular scissors to cut out the proper thickness shims from a stainless steel shim assortment that I bought at my local Ace Hardware store.
Then I replaced the rotor, torqued the lug nuts, and checked the runout again. It took awhile, but I got the rear runout to be less than .002.
