Motive Power Bleeder
Old Jan 24, 2012 | 09:56 PM
RebarIV's Avatar
RebarIV
Default Motive Power Bleeder
Ok. I know that I will be repeating things that many of you already know, but I just wanted to sing some praises of the Motive power bleeder. This thing is worth its weight in gold. I can honestly say I would probably pay double what they ask for it. To anyone who doesn't have one of these, I would highly recommend it. Got mine last week, and used it for the first time tonight after I replaced a caliper. It literally took me 2-3 minutes to completely bleed a dry caliper. It took me a few minutes on the initial set up to get fittings tight enough so they don't leak any air. This thing is a breeze to use, and leaves me wondering why I ever bleed them any other way. I don't remember who initially mentioned this when I was reading different threads a few weeks ago, but a big thanks to all of you who mentioned it so I could find out more about it when I searched the forum for info on it. Forever changed my brake bleeding experiences.
Old Jan 25, 2012 | 05:14 PM
FKING1's Avatar
FKING1
I could never get it to seal on the master cyl of my 70 no matter what I did.
Tried to file the top flat but always leaked, often all over the floor.
Finally gave up and took the car to a shop.
Trying to sell the Motive.
Old Jan 25, 2012 | 05:22 PM
billla's Avatar
billla
St. Jude Donor '14
I originally bought mine just to do the brakes on my '03 Z06 between autox's, but I bought the other adapter kits and I've used it on just about everything.
Generally, the problems I've seen with leakage are too-high pressures - it doesn't take a lot
Old Jan 25, 2012 | 05:49 PM
thegavel's Avatar
thegavel
I just made up one of these.....worked perfectly (and on other vehicles too). Cheap & Easy (just like ME !!!!).
Old Jan 25, 2012 | 06:39 PM
Bowerss2's Avatar
Bowerss2
the motive is the bomb diggity. its a bit tricky to seal at first but once you get the hang of it it is irreplaceable.
Old Jan 25, 2012 | 06:52 PM
Mooser's Avatar
Mooser
I put a large c-clamp from under the master to about the center of the plate. No Leaks
Also, I don't put fluid in the tank, just top up the master and use the tank for pressure. Figured if anything did leak it's just air and not fluid running down everywhere
Old Jan 25, 2012 | 07:07 PM
75vetteman's Avatar
75vetteman
From: some hole in the ground town- camp verde:) arizona
well all those fancy tools may help, but when i replaced my calipers i just let gravity do the work. didn't take too long and was cheap and simple. the first caliper didn't want to start flowing so i had to hook up a line over the valve and starting sucking on it. ended up with a mouthful of brake fluid the third time i did it (still thought it wasn't filling up) ah good times, good times.
Old Jan 26, 2012 | 12:28 AM
RebarIV's Avatar
RebarIV
Lol. Bet that brake fluid was tasty. I only pumped it to 10 psi. Didnt want to take any chances. I love it though. Ill be buying adapters for my other cars soon.
Old Jan 26, 2012 | 06:20 PM
75vetteman's Avatar
75vetteman
tasty indeed fortunately after i got that one flowing all the rest did so on thier own. i just don't see the point in buying fancy equipment when i can do the same thing for free in nearly the same time. unless i worked in a shop doing this for a living, i don't see the point.
Old Jan 26, 2012 | 06:34 PM
babbah's Avatar
babbah
No need for Motive Pressure Bleeder - Simply use a mighty vac at each caliper - Job Done - No Muss No Fuss
Old Jan 26, 2012 | 06:50 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
+1 for a fan of the Motive bleeder! It is an awesome tool, so glad I have one. Sure beats brake fluid in my mouth!!!
Old Jan 26, 2012 | 07:33 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Assuming you put brake fluid in the tank, doesn't it have to be cleaned out when you're done with the bleeding and isn't that kind of a pita?
Old Jan 26, 2012 | 09:03 PM
ricspeede's Avatar
ricspeede
5th Gear
Default Motive Products Bleeder
I always bled the old way with the wife in the drivers seat, but this time we monkeyed around for a long time with no success. So I bought a Motive Products. I could not get a seal using one c-clamp, but I found that two of those wood-working clamps, (the ones with the pistol grip like a caulking gun, and nice rubber pads to protect the MC) were prerfect.
Bleeding took about ten minutes. The only moment of doubt I had was when it was time to remove the cap on the MC. Was I gonna have fluid all over? They tell you to tilt the bottle so that additional bleeding will only draw air. I did this til there was no fluid in the bottle-to-MC hose.
Then I bled drivers front til there was about 4 inches of fluid in the hose from the caliper. Then I bled drivers rear til there was about 2 inches of fluid in that hose. When I pulled the cap there was no spillage, and I had to add a little fluid to the MC.
Oh yeah, the pedal is perfect.
To Motive Power Bleeder
