200 4R options?
What all is involved? what changes are necessary to the drive shaft? How about the cross member?
I was looking at Bow-tie overdrives but other then their home page a lot of it is down including their catalog. Are they still in business?
What other makes out there are good? I have heard to avoid TCI but other then that i dont know. What about torque converters? what is a good brand?
Specs Engine around 450 at the crank, rear end 3.55:1.
I rebuilt my own maybe 6 years ago, in the car fine....336 rear....
when you buy a converter, you will find the typical converter has what is known as 'paper clutches' ....now the EARLY 700 and the 200 used to share the same converter, but ~87 up 700 went to more splines and KEVLAR clutches in the converter,.....the 200 stayed the same....
NOW, I am told by my tranny supply shop they can get me a 200/early 700 converter, rebuilt with the heavy duty Kevlar clutches...
I am now facing a intermittant lockup problem, hot on the freeway and it will not lock up, cold it will....went the easy fix stuff, no go...so converter time when my lazy/cheep *** gets to it....yawn....
The swap is straight forward; no driveshaft mods. You need to consider how you will lock up the converter, There are kits available, but it's really not hard to wire up something on your own. Same goes with the TV cable. you'll need the correct brackets to interface to your carb.
Your stock crossmember will work, but it is a tight fit around the exhaust. The BTO crossmember lets you route the pipes easier.
Might the lockup problems you now have be due to not having a lockup controller (resulting in L/U clutch damage)? I'm not trying to be "testy" here, but advising others to not use a lockup controller is questionable, IMO...for the very reason you are now discovering.
)If you look at how this actually works inside the transmission, it's really not a problem, I swear!! I've been running this way for a couple years now, as have others with no issues, none. You simply do not NEED a controller. It's a nice, but a little expensive OPTION. BTW, I first got the idea of using a switch from a guy in NY who has a very strong reputation for building these things, for both street and race use. It's his lively hood, not a hobby like it is for you and I and it works for him. Gene's problem has nothing to do with a controller, really.
The lockup can be controlled very easily with a relay and brake switch with a two pin 4th clutch pressure switch. It's not rocket science
)If you look at how this actually works inside the transmission, it's really not a problem, I swear!! I've been running this way for a couple years now, as have others with no issues, none. You simply do not NEED a controller. It's a nice, but a little expensive OPTION. BTW, I first got the idea of using a switch from a guy in NY who has a very strong reputation for building these things, for both street and race use. It's his lively hood, not a hobby like it is for you and I and it works for him. Gene's problem has nothing to do with a controller, really.the brake control consists of a separate switch in the +12 line, obviously ignition controled and routed through the BWD S870 switch that is a plug in for our units but has a extra switch to OPEN the 12 volt feed to lockup when we press the brakes/light the lights....
you CAN do the same with a relay if you know how....
The local tranny supply house I deal with is where I got the converter from, and so I went through the logic on the vette, and so it seems the converter OR the O ring on the tranny input shaft is defective....funny in that it only locks when COLD, but soon as it makes it to the freeway about 3 miles through heavy traffic, it's not locking up at all.....
I"m told by the tranny supply that the 200 and EARLY 700 had the same converter, but long about '87 or so they upgraded the 700 to a KEVLAR clutch converter, and changed the spline count....
the 200 converter remained a 'paper' clutch ....BUT they can s/order me one with Kevlar....
money/taxes/springtime bad news time of year now, be a few more weeks, and other plans take precedence anyway....
