New style axles
Even if they could be made to work, what's the advantage?
but ... I not would expect someone who refers to axles as "bars" to understand these concepts.
They must have some type of advantage over the old style, otherwise why would they use them in their top performance car, as well as their other performance oriented IRS cars?
What Mike said is correct.
As I mentioned, CV joints are not used to add strength nor save weight. They are disadvantaged in both respects to comparable u-joints.
In fact, for high power and/or off-road applications, it's not uncommon to convert CV joint axles to U-joints.
I had no idea what he was on about.No, they won't work with the C2/C3 driveline/suspension layout without 1) relieving the axle shafts of their role as upper links by installing some system of additional ones, and 2) adapting/matching available hardware up with flanged inner yokes and the outer stub flanges. It's entirely plausible, and I've done a bit of homework on this one myself as part of a larger concept, but such kit isn't exactly the sort of thing you'll likely ever be able to buy off the shelf.
FWIW, there are CV's in the aftermarket rated to 900 HP and higher, and can be found on the back end of many a modern formula car.
So, if they are so inferior to u-joints, then why are they pretty much universally used by every auto manufacturer in modern cars?
I once heard a very wise man say, "The systems used on F1 cars have about as much in common with street cars as a duck does with a bowling ball."
Precisely. CV joints are predominantly used in FWD cars where large steering angles would generate unacceptable acceleration and deceleration per revolution... no big problem when wheels are pointing straight ahead. Not needed at all in RWD Corvette where angles are minimum.
Joe
BTW, C6...
Quite possibly, and wouldn't surprise me! This is an interesting topic, I am going to ask a person I consider very knowledgeable about this, the owner of a race shop that builds serious road race C5 and C6 Corvettes, which is local to me. These guys know their stuff:
Powell Raceshop
Me too!
Love that the guy can't use "spell check" and typical attitude of the youth of America today.... They already knew that
I forgot, one other advantage, if you want to go to a 4wheel steering system, they will work over a wider range of miss-alignment too......May as well go with a trans axel swap too.....
That being said, I do know several people that have very high rwhp/tq C5 and C6's (including one C5 that is in the 1200rwhp range) that do not have an issue with breaking cv joints or the halfshafts, and these cars are not babied in any way.....but these cars are street driven and/or road raced only and not drag raced with slicks, which is where breakage is much more likely to happen.
On a chassis dyno, the drivetrain losses on our cars are much, much higher than that of a C5 or C6, and I have to believe that the CV joints play a part in that.
Yep, when straight, or nearly so, there should be no loss of HP. Another point I don't think has been mentioned: how well can a CV joint withstand axial loads. We know the U-joints can as our half-shafts are under constant compression in the normal state. C5/6 half-shafts have one CV joint that is made to allow axial movement - the axle can be compressed and extended as the suspension moves up and down. Knowing that, you couldn't just use a C5/6 half-shaft as-is, you'd have to replace one CV joint (the one that extends and compresses) with a standard CV. As I mentioned in my early posts, the cost of modifying the half-shafts to fit a C3 would be pretty high. Only a determined guy with a shop with all the machine tools at his disposal would try it. It would have to be a labor of love, because the cost wold be beyond any advantage of the CV setup.
Pete
