1982 a/c compressor
Old Jan 26, 2012 | 08:35 AM
Stickman82's Avatar
Stickman82
Default 1982 a/c compressor
I need the correct Delco model number for the a/c compressor in a 1982 CE. The one in my car today is a 1131198 (toast). As I look for a reman I want to make sure I get the correct one for the car.
Thanks!
Old Jan 26, 2012 | 12:05 PM
1yy07's Avatar
1yy07
Default ac compressor
DO NOT BUY A REMAN go to the dealer or i think orileys carryes NEW ones.
Old Jan 26, 2012 | 01:07 PM
rmm82's Avatar
rmm82
1131198 is the same model number on my 82 CE. The only other element of interest on my AC label is one called Code # which is 112711. Although I'm not sure what it means.
Old Jan 26, 2012 | 01:33 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have your original rebuilt.
Old Jan 26, 2012 | 01:51 PM
hugie82's Avatar
hugie82
Who rebuilds them and how much should we expect to pay? Mine is on its last leg too
Old Jan 27, 2012 | 08:37 AM
kevakasper's Avatar
kevakasper
2017 C4 of the Year Finalist
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
I bought a N.O.S. R4 on e bay for about $125 last year for my 82 CE. There were a lot of cars that used that compressor. I drained the old oil and refilled with R134 compatible oil before the install. While it was apart I replaced the a/c pressure switch, drier, accumulator, lineset, and ALL O rings. Also VERY important, flush the rest of the system and add oil for any of the replaced components.
A/C works flawlessly now. My total out of pocket was about $300.00
Old Jan 27, 2012 | 08:55 AM
Stickman82's Avatar
Stickman82
Thanks for all of the suggestions! Mike, do you know of a rebuilder?
Old Jan 27, 2012 | 10:04 AM
7T1vette's Avatar
7T1vette
If your compressor threw 'craps', you will want to flush the refrigerant lines out completely to get any debris out of them. Then they will have to be purged of any [and all] fluid and vacuum ALL air out of them before refilling with refrigerant. You really should have a professional A/C mechanic do this work, if you want it to be right and last.
Old Jan 27, 2012 | 11:17 AM
hugie82's Avatar
hugie82
That sound easy. Where do u get the parts for it?
Old Jan 27, 2012 | 02:11 PM
kevakasper's Avatar
kevakasper
Rock Auto online
To 1982 a/c compressor
