Bee Jay's lightweight battery mod! 25lbs saved!
Old Jan 31, 2012 | 01:23 AM
Bee Jay's Avatar
Bee Jay
Default Bee Jay's lightweight battery mod! 25lbs saved!
I spent over two months losing five lbs with my hood, and almost two weeks losing seven pounds with my MC. I needed a quick and easy weight loss mod. This took me two hours. First I ordered a Deka ETX20L battery from amazon. The Costco battery I had in the car weighs 40lbs. This lightweight AGM battery weighs 15lbs. You can see how I mounted my side mount cables. I think I will just lay the battery down on it's side and figure a way to secure it.
I saved 25lbs!!!. That was too easy. The car started right up. I need to spend a day with it. Aluminum radiator or Rack and Pinion next.
Bee Jay
Old Jan 31, 2012 | 01:54 AM
7T1vette's Avatar
7T1vette
I think we are witnessing the first documented case of "auto anorexia" here. Is there some underlying purpose to this weight-loss marathon, or has it developed into its own 'purpose'?
I know that serious road racers try to get their cars as light as is allowed by their rules; but those folks don't seem to care about others knowing how much they 'lost'.
But, if it hasn't become a compulsion [yet], I guess you should "do whatever makes you happy"....
Old Jan 31, 2012 | 03:16 AM
Shark Racer's Avatar
Shark Racer
One of the guys in C6Z has got bee jay beat, Halltech got one of those cars under 3k#...
Old Jan 31, 2012 | 05:20 AM
6t7gto's Avatar
6t7gto
What's the cca on the small battery?
david
Old Jan 31, 2012 | 05:47 AM
OzzyTom's Avatar
OzzyTom
CCA appears to be 310A on the label....
Beejay... It looks to be a Lead / Acid battery, and as such I doubt it should be laid on its side.
It states it is non-spillable, but during charging there is the possibility of acid leakage due to pressure build up in the cells. Keep an eye on it.
Old Jan 31, 2012 | 06:48 AM
aussiejohn's Avatar
aussiejohn
Default Move the battery.
Bee Jay,
Have you weighed the battery cables? They probably now weigh more than your battery. Seriously, if you could move your battery to where the AC unit used to be, or tuck it into the front fender near the starter motor, then you could run a much shorter positive cable. That would save a few pounds.
A friend just wired up a twin electric fan for my truck, and used wire that looked too thin. He works full time for a company that makes wiring looms for V8 Supercars, Holden Commodore and Ford Falcon based racing cars, and they all use this very thin wiring. They run electric fans on what looks to be 20 gauge wire and it is all due to the type of wire they use.
This modern wire is expensive, but it will handle current that would melt a C3 Corvette's wiring loom. I'm sure they make heavier duty cable for starter motors, and with the short distance from the battery to the starter as I mentioned above, you could even downsize the diameter of those battery cables to save even more weight.
Regards from Down Under.
aussiejohn
Old Jan 31, 2012 | 11:05 AM
Vette5.5's Avatar
Vette5.5
You're maybe wanting to check the Shorai battery site as have a 36 ah motorsports battery that only weighs 5 lbs. Guy in the C6 ZO6 section is using one of these, and quite happy with it. $350 bucks though, but "batterystuff.com" has it for the bargain price of $315.
Old Jan 31, 2012 | 11:42 AM
7t9l82's Avatar
7t9l82
radio control it, that will take alot of weight out. lol
Old Jan 31, 2012 | 11:43 AM
Bee Jay's Avatar
Bee Jay
It is an Absortion Glass Mat (AGM) battery. Matter of fact, these guys, Deka, also make the Braile batteries. You can mount anyway but upside down.
Amazon had them for $85 shipped.
Bee Jay
Old Jan 31, 2012 | 01:29 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
How about no battery at all and just use one of these :
Seriously though, you got the best documentation for having a light weight C3, well done!
Old Jan 31, 2012 | 01:33 PM
wan2run's Avatar
wan2run
BeeJay - any idea what the car weighs now?
Old Jan 31, 2012 | 03:50 PM
scottyp99's Avatar
scottyp99
If Bee Jay makes his 'vette any lighter, he's gonna need to tie it down so the wind won't blow it away!
Scott
Old Jan 31, 2012 | 04:36 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
It all adds up. Actually, copper battery cables weigh enough that back in my drag racing days we would run aluminum ones (Moroso) from the trunk box to up front.
Old Jan 31, 2012 | 05:52 PM
spedaleden's Avatar
spedaleden
At the rate your going your car should weigh 1500 pounds.
Old Jan 31, 2012 | 07:00 PM
gofastvette's Avatar
gofastvette
definitely lighter by weight, but will it continue to produce...looks like a Harley battery
Old Jan 31, 2012 | 09:15 PM
jay_c3's Avatar
jay_c3
With a much smaller battery could it over charge it.? Could you go with a smaller lighter alternator?
Old Jan 31, 2012 | 09:39 PM
SuprJames's Avatar
SuprJames
I was looking at Braille batteries for my V8 Miata project. I think they weigh around 17 lb. IF it works out I'll probably replace my REALLY HEAVY POS Optima battery in the '72 with it.
To Bee Jay's lightweight battery mod! 25lbs saved!
Old Feb 1, 2012 | 12:17 AM
Ray Y's Avatar
Ray Y
OK OK, you win the ultra light weight battery contest.
Personally I went with the Braille Carbon Fiber cased B3121C battery. 21 lbs BUT it offers:
892 Cranking amps
550 Cold Cranking Amps
1380 (PCA) Pulse Cranking Amps
This will be my 3rd season on this Braille battery on the 555 cu in 10.3:1 motor. It has never failed me.
Bee Jay you are truely an inspiration in the "get-r-lite" world of Vettes!
Cheers
Ray Y
Old Feb 1, 2012 | 06:40 AM
cv67's Avatar
cv67
St. Jude Donor '05
892 Cranking amps
Sounds good! $300 bones though ouch.
Gotta lose some weight here, too.
Scattershield added 40 lbs
Loop will add a few..keeps going.
Old Feb 1, 2012 | 09:27 AM
Bee Jay's Avatar
Bee Jay
We will find out over the next few weeks, months, years. At $85, I can buy another one. And I still have the 40lb monster. I've been told that I need to pretty up the connections. I'll do that, but I want to keep it convertible, so that I can throw the original side post in if needed.
My buddy Paul is buying on the aluminum radiator thread, so I get his aluminum radiator. That should be another 15lbs. Stay tuned.
Bee Jay
