REV-Limiters
Old May 14, 2002 | 08:47 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default REV-Limiters
What do you guys use as REV-Limiters??
I was thinking about getting Autometer PRO-Control but it seems that noone here has experience with it.
:cheers:
Olivier
Old May 14, 2002 | 08:49 AM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: REV-Limiters (GrandSportC3)
I use the MSD 6AL ignition with it's built in rev limiter. I like MSD ignitions and have a total of 4 different ones in my car.
Old May 14, 2002 | 08:54 AM
GrandSportC3
Default Re: REV-Limiters (norvalwilhelm)
I read somewhere that the MSD 6AL can melt the HEI cap if used with GM HEI Ignition.... I also was considering the CRANE HI-6 Ignition but I don't know if HI-6 works with GM HEI with internal coil...
:cheers:
Olivier
Old May 14, 2002 | 09:13 AM
norvalwilhelm
I don't know about that. I have a Mallory unilite distributor and have run it with the MSD for more then 10 years without problems.
Old May 14, 2002 | 09:21 AM
ylose's Avatar
ylose
I read somewhere that the MSD 6AL can melt the HEI cap if used with GM HEI Ignition.... I also was considering the CRANE HI-6 Ignition but I don't know if HI-6 works with GM HEI with internal coil..Olivier
wow...haven't heard that one yet....but I run a msd HEI distrib and a Blaster High Vibration Coil with the ability to mount at any angle. you can see it on my firewall in the picture. My msd is above the front passenger tire and like Norval I use it to manage the REV limits...MSD6al :cheers:
bah...picture is old...I removed the flame-thrower air-cleaner !:lol:
[Modified by ylose, 7:24 AM 5/14/2002]
Old May 14, 2002 | 09:47 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: REV-Limiters (ylose)
MSD 6AL, here and I just bought a two step rev controll so when those ricers rev their engines at me at the stop lights I can powerbrake it at the low rev limiter and scare the Bejebus out of them :lol:
Seriously the two step should be great at the track :D:D
Old May 14, 2002 | 09:57 AM
Clink69's Avatar
Clink69
MSD6AL with a 6K limit. hit is all the time...
Chris
:flag
Old May 14, 2002 | 10:34 AM
BeaterShark's Avatar
BeaterShark
I have an MSD rev limiter box. It uses the same pills as the 6AL, but it is only a rev limiter. I have not hooked it up yet, but will be doing so over hte Memorial Day weekend. The P/N is 8728.
Old May 14, 2002 | 10:46 AM
GrandSportC3
Well - your coil is external - so you won't have a problem. The problem seems to
only with the internal coil. I just found following statement about the MSD 6AL with
stock HEI on the SUMMITRACING website:
(Quote)
The resistance in the stock cap is too high and may cause the cap to melt.
(Quote)
:cheers:
Olivier
Old May 14, 2002 | 11:12 AM
ylose's Avatar
ylose
:eek:
:eek:
thank god mine is a complete aftermarket system.... :yesnod:
[Modified by ylose, 9:12 AM 5/14/2002]
Old May 14, 2002 | 11:49 AM
Chuck Harmon's Avatar
Chuck Harmon
I use the MSD distributor and 6AL with a 7K chip. It works so much more smoothly than the limiter on my ZO6 that shuts off the gas when you hit it.
Chuck
Old May 14, 2002 | 11:54 AM
Gordonm's Avatar
Gordonm
Default Re: REV-Limiters (Chuck Harmon)
I use a Crane HI6 in mine. Works very well. Has been used many times. It says it works with the HEI ignition.
Old May 14, 2002 | 01:17 PM
GrandSportC3
Default Re: REV-Limiters (Gordonm)
Well - there are different type of HEI's. (external and internal coil).
I use a aftermarket HEI with 50000 Volt internal coil...
:cheers:
Olivier
P.S. It's very likely that I will go with the HI-6 Ignition myself
Old May 14, 2002 | 01:22 PM
GrandSportC3
:eek: The resistance in the stock cap is too high and may cause the cap to melt. :eek:
Mine is a aftermarket system too. However - it's the same design as the stock HEI.
:cheers:
Olivier
Old May 14, 2002 | 03:24 PM
gkull's Avatar
gkull
Crane HI6R it's the only real choice other than MSD digitals. Mine is mounted infront of the passenger wiper.
Old May 14, 2002 | 03:38 PM
GrandSportC3
Default Re: REV-Limiters (gkull)
Do you use a internal or external coil?
:cheers:
Olivier
Old May 14, 2002 | 03:40 PM
terryrudy's Avatar
terryrudy
If ya got the MSD, you can make your own pills: http://www.corvettefaq.com/c3/Rpm_ohms.xls
-terry
To REV-Limiters
Old May 14, 2002 | 03:42 PM
inqbus383's Avatar
inqbus383
Summit sells a lower resistance cap which will not melt for sure, if you are in doubt. I have that with my 6AL and haven't had any problems. It is listed as optional accessories for the msd box at the summit web site.
Old May 14, 2002 | 03:46 PM
GrandSportC3
Default Re: REV-Limiters (inqbus383)
I have a PROFORM 50000 Volt HEI Ignition. I don't know about the resistance of the
cap used for this ignition. I might change it if necessary...
:cheers:
Olivier
Old May 14, 2002 | 05:02 PM
gkull's Avatar
gkull
mallory unilite - MSD Blaster II coil - Balast Resistor - Taylor 10.4 mm pro spiral wires - Some kind of Platinium plugs. Right now Crane is giving a super coil with every ignition. I bought mine to early to get the coil deal.
The Crane wiring is great. I can pop the hood and unplug two connectors and eliminate the box if something should go wrong with it. My old MSD 6AL left me stranded
